simpletools code to C conversion, can't figure it out.
Beavis3215Beavis3215 Posts: 224
edited 2018-07-15 - 22:39:04 in Propeller 1
I have some code examples for using DIRA, OUTA and waitpeq, but nothing as simple as the C equivalent of on_sensor = input(19) or if (on_sensor == 1).
Here is what I mean
void button_time();
static volatile int delay;          // delay is global
int main()                          // Main function
 cog_run(button_time,128);          // Push button control runs in other cog
 set_directions(17,16,11);
 int on_sensor;
 int off_sensor;
  while(1)
    on_sensor = input(19);
    off_sensor = input(18);
    if (on_sensor == 1)
      set_output(17,1);             // Turn magnet on
    if (off_sensor == 1)
      pause(delay);                 // Delay is assigned in button_time
      set_output(17,0);             // Turn magnet off
      set_output(16,1);             // Timing light on
      pause(5);
      set_output(16,0);             // Timing light off
This Works
This is what Im trying to do
void button_time();
 int on_sensor = 1 << 19;
 int off_sensor = 1 << 18;
  DIRA &= ~(1 << 19);
  DIRA &= ~(1 << 18);
  while(1)
   off_sensor= input(18);
    if (on_sensor == on_sensor)
    if (off_sensor == off_sensor)
      pause(5);
Just tying to understand the inputs for now. It seems like I should be pretty close.
Is there somewhere in help that talks about this?
The Propeller is like cool and stuff..... uhhh.....huh huh.
  • JonnyMacJonnyMac Posts: 6,142
    edited 2018-07-15 - 23:15:17
    I'm not a Propeller C programmer, so I hope I don't screw you up. Perhaps you can create a general purpose function like this to check the state of any pin. If I've done this correctly, it should return 0 or 1.
    (edited to correct syntax)
    int get_pin(int pinNum) {
      return (INA >> pinNum) & 1;
    This doesn't change the direction of the IO pin which can be useful when using it to monitor the output state controlled by other processes.
    Jon McPhalen
    Hollywood, CA
    It's Jon or JonnyMac -- please do not call me Jonny.
  • Here's the code for the input function in the simple library
    int input(int pin)                            // input function definition
      int mask = 1 << pin;                        // Set up mask
      DIRA &= ~mask;                              // AND DIRA with NOT mask
      return (INA & mask) >> pin;                 // Return input state
    It returns the value of the pin. Note that it also forces the pin to be input only.
  • Thanks Dave
    Awesome as always
  • void button_time()
      //set_directions(13,8,0b111111);
      int lights = 0b111111 << 14;       //Timing delay in binary on LED's
      DIRA |= (lights);
      int t = 20;
      //int advance;
      //int retard;
      int advance = 1 << 15;
      int retard = 1 << 14;
      while(1)
         if ((INA & retard) == retard)   // If retard button high
           t = t + 1;
           if (t > 64)                   // Don't allow t to exceed 64
             t = 64;
         if ((INA & advance) == advance) // If advance button high
           t = t - 1;
           if (t < 1)                    // Keep t 0 or larger
             t = 1;
         delay = t;                      // Pass delay to main function
            //set_outputs(13,8,t);         // Put t value on output lights
            OUTA |= (t << 14);
            pause(300);
    The simpletools code is remarked out as to be non operational. I am attempting to replace the simpletools code with C code, but I am making a mistake. I don't quite get it, any Ideas?
    Dave, I also tried to find in simple libraries the C code conversions of simple code, but I can't find it. Can you get me the path through Simple IDE help to get to them?
  • It returns the value of the pin. Note that it also forces the pin to be input only.
    But any other cog can make the pin an output, right?
    Prop Info and Apps: http://www.rayslogic.com/
  • Dave HeinDave Hein Posts: 5,749
    edited 2018-07-22 - 23:47:47
    @Beavis3215, to set bits 8 to 13 to the 6-bit value of t you should do
    OUTA = (OUTA & ~(0b111111 << 8 )) | (t << 8 );
    You have to first zero out the 6 bits, and then or in the new value.
    To set the direction of the 6 bits to outputs you should do
    DIRA |= 0b111111 << 8;
    You can find the location of the library code by clicking on Tools and then Properties. Or you can just hit the F6 key. Look for "Library Folder" to find the location. The source for the pin I/O routines is located in the Utility/libsimpletools/source folder.
    @Rayman, you are correct. Any other cog can make the pin an output.
  • Thanks Dave, I got it to work. This one has been educational for me.
