SX28 Datasheet Quick Read Through
Found the answer to why the instruction set I read threw me off the one time.
A superset of these instructions are available in the SASM
assembler of the SX-Key IDE, and supported by the SX
Key User’s Manual. Both are available for free download
from www.parallax.com/sx.
This 'Native' instruction set is more to my liking.
43 instructions. Very PIC like.
Manual is like a breath of fresh air compared to Microchip datasheet.
This SX datasheet was either written BY Parallax or with their co-operation.
Will post link to it.
  • Here's the link.
    https://www.parallax.com/downloads/sx20ac-and-sx28ac-datasheet
    This is a FINE piece of writing.It is done by Parallax.
    Yet it within the constraints of working with a set piece of hardware.
    It is copyrighted 2008.This is most excellent!
  • Here's another little 'nugget of gold' in here.The internal oscillator.
    The internal RC mode uses an internal oscillator, so the
    device does not need any external components. At
    4 MHz, the internal oscillator provides typically +/-8%
    accuracy over the allowed temperature range. The internal
    clock frequency can be divided down to provide one of
    eight lower-frequency choices by selecting the desired
    value in the FUSE Word register. The frequency range is
    from 31.25 KHz to 4 MHz. The default operating
    frequency of the internal RC oscillator may not be 4
    MHz. This is due to the fact that the SX device requires
    trimming to obtain 4 MHz operation. The parts shipped
    out of the factory are not trimmed. The device relies on
    the programming tool provided by the third party vendors
    to support trimming.
    Figure 9-
    What that means to us is you can run it at 31.25 khz.That is k hertz not mega.
    That means you can write simple 32 count delay loops.Instead of loop upon loop to slow down a fast chip.
    Another tidbit is it says 'Fuse' about some of the registers.That is early terminology of micro's.
    Replaced by 'configuration'.
  • Do you talk to yourself at the bus stop, too?
  • May I resume here?
    Looking at the Configuration section of manual.
    There is no Config line like with PIC's.
    You do the configuration with the programmer.SX Blitz or SX Key.
    A little strange but I can live with it.
  • microcontrolleruser,
    PIC programmers not only write to the program into program memory, but also write to data to the EEPROM and burn in the Configuration Bits.
  • Thanks Genetix
    Yes.Different.That's for sure.
    The SX Key also runs at 20mhz while it programs.That's kind of odd.
    Then when it is debugging it does the same.
    Guess it was a tradeoff to get the debugger built into the programmer at the time.
