Print a hex value in VGA — Parallax Forums
It seems that none of the VGA objects have a print hex method. I've tried putting one in from PST and several others but get weird numbers. What is the correct way to print a hex in VGA? I want to print time from a RTC
Aaron
  • Use the hex method in the SimpleNumbers library object to convert the number to a hex string. Then print to VGA with the str method.
    (IMO, putting methods like hex and dec in every I/O object is a redundant waste of memory.)
  • avsa242avsa242 Posts: 430
    edited 2018-05-25 21:32
    Hi Aaron,
    You probably want the VGA_Text.spin object from the Propeller Tool library, or the equivalent display.vga.text.spin from https://github.com/parallaxinc/spin-standard-library, which both have hex methods.
    Usage:
    vga.hex (value, digits)
    Cheers,
    Jesse
    Edit: Doh! Too late...
    Thanks Phil that did it.
    Thanks to Jesse also.
    Aaron
