Forum Update - Announcement about May 10th, 2018 update and your password.
Activitybot C code for qti sensors won't run
Hi
We are having trouble loading code for qti sensors from the Activitybot C code folder (most recent version). We keep getting this error: simpletools.h: No such file or directory. We are using the most recent version of the Learn folder. Does anyone know how we can fix this?
  • 6 Comments sorted by Date Added Votes
  • Please post your code, preferably between code blocks (click on the "C" in the edit bar and paste your code between them.
    thanks
    Tom
  • I would seem that where ever you have the QTI library it is outside the SimpleIDE folder.
    It's having a problem finding the base include files.
  • #include "simpletools.h"
    #include "abdrive.h"
    // ------ Global Variables and Objects ------
    int item;
    int left = 0;
    int leftPrev = 0;
    int right = 0;
    int rightPrev = 0;
    int driveLeft, driveRight;
    int scale = 1000; // Recommended speed at scale = 1000.
                      // To make it go 1.25 times as fast, change scale to 1250.
                      // To make it go 0.75 times as fast, change it to 750
    // ------ Function Declarations ------
    int getQTIs(int highPin, int lowPin);
    // ------ Main Program ------
    int main()
      drive_speed(0,0);
      pause(1000);
      drive_setAcceleration(FOR_SPEED, 2000);
      while (1)
        QTIs();
        switch (item)
          case 0b1000:
            left = 0;
            right = 32;
            break;
          case 0b1100:
            left = 16;
            right = 32;
            break;
          case 0b1110:
            left = 32;
            right = 46;
            break;
          case 0b0100:
            left = 46;
            right = 64;
            break;
          case 0b0110:
            left = 64;
            right = 64;
            break;
          case 0b0010:
            left = 64;
            right = 46;
            break;
          case 0b0111:
            left = 46;
            right = 32;
          case 0b0011:
            left = 32;
            right = 16;
            break;
            break;
          case 0b0001:
            left = 32;
            right = 0;
            break;
          default:
            if(leftPrev > rightPrev)
              left = 32;
              right = 0;
            else if(rightPrev > leftPrev)
              left = 0;
              right = 32;
            else
              left = 64;
              right = 64;
        driveLeft = scale * left / 1000;
        driveRight = scale * right / 1000;
        drive_speed(driveLeft, driveRight);
        leftPrev = left;
        rightPrev = right;
        pause(20);
    // ------ Functions ------
      set_outputs(7, 4, 0b1111);
      set_directions(7, 4, 0b1111);
      pulse_out(26, 230);
      set_directions(7, 4, 0b0000);
      pulse_out(26, 230);
      item = (get_states(7, 4));
      //print("%04b\r", item);  // uncomment to view in terminal
  • RichTRichT Posts: 7
    edited April 16 Vote Up0Vote Down
    THanks. The qti folder is inside the Simple IDE learn folder. One of the qti programmes runs, the one I posted doesn't.
  • When I tried to compile the code above I got a couple of errors.
    The first was the ";" after the function name (line 96 in SimpleIDE).
    There should not be a semicolon after the function name in the function.
    The next was line 30, the line before the switch statement
    QTIs();
    I think this should be
    getQTIs(pin number, pinnumber);
    I'm not sure what highpin and lowpin are in your program. I just used 7 and 6 to see if it would compile and it did.
    getQTIs(7, 6);
    I did not get an error
    My version of SimpleIDE is 1.1.0, and I have the 1/23/18 library update.
    Hope this helps
    Tom
  • Thanks. I will try this.
