Trying to install propelleride
Hello all-
Im trying to install propelleride on my linux machine, Cutting and pasting the commands on the download page and I get this error:
dpkg: error processing archive propelleride-0.33.3-amd64.deb (--install):
 cannot access archive: No such file or directory
Errors were encountered while processing:
Im not the brightest when it comes to linux (which is why i installed it to get better), can anyone help?
Shawn
  • You need to run the dpkg command from the directory that contains the package file.
    Presuming you downloaded version 0.33.3 to your Download directory then:
    $ cd Download
    $ sudo dpkg -i propelleride-0.33.3-amd64.deb
    Or you could specify the path and do it from whichever directory you are currently in, for example:
    $ sudo dpkg -i /home/yourUserName/Download propelleride-0.33.3-amd64.deb
  • Heater. wrote: »
    $ cd Download
    Ohh, okay got ya. Thanks so much
  • I usually use a double click on a *.deb file after it is downloaded.
    I am using Linux Mint.
    Yes Frida is my watchdog!
  • frida wrote: »
    where does it put the program? I tried that and it said it installed but darn it if i can find it in my system
  • Try typing "prop" into a command line terminal window and then hit TAB. If it's installed on the PATH then it will show up.
    Sorry I have never installed it from a deb package so I'm not sure exactly where it gets put.
  • Shawn Lowe wrote: »
    frida wrote: »
    If it did install you should be able to use the 'which' command to show you the location, assuming it was installed into a location that is in your $PATH environment variable.
    You could also try:
    To find a specific package's location you can use the dpkg command with the -L flag. For example if you wanted to find all of the installed files for Apache2, you could run:
    dpkg -L apache2
    Along with 'Antimatter' and 'Dark Matter' we've recently discovered the existence of
    `Doesn't Matter`, which appears to have no effect on the universe whatsoever.
  • It's hiding here.
  • Thanks everyone for the help. When I get some time I will investigate. BTW, im running ubuntu. I am unsure of the version.
  • Well thanks to all your help, i now have propelleride on my linux desktop. It has no example library!? Oh well, thank you again
  • The spin-standard-library is a good start, IMO. I think, sadly, it's unmaintained now, but I think it is a good idea that has a lot of the basics in it.
    Cheers
    WIP Spin drivers for various devices: lsm9ds1 IMU (SPI), Newhaven 4x20 OLED (I2C), Melexis 90621 Thermal imager (I2C), SHT3x Temp/RH (I2C), SSD1306 OLED (I2C; P1-SPIN, P2-SPIN2), AMS TCS3x7x RGB Color Sensor (I2C), MAX31856 Thermocouple Amp (SPI), BMP280 Baro. Press/Temp (I2C), Trinamic TMC2130 Stepper Driver (SPI), nRF24L01+ Driver (SPI)
  • If you go to Edit Preferences, then Browse Library, you will find a lot.
