Conditional execution of a hub memory operation
If I conditionally execute a hub memory operation, say , set the flags so it wont run if the zero flag is set, and the instruction ends up not running, how long does it take? 4 like a noop? 8 for the minimum time it would take to run? However long it would actually take to run?
Particularly patient proactive practice positively predicates practically precise poly-processor Parallax Propeller programming paradigms.
  • If it doesn't run, it doesn't run. So four clocks.
    “Perfection is achieved not when there is nothing more to add, but when there is nothing left to take away. -Antoine de Saint-Exupery
  • As Phil says, the Hub sync operation only occurs if the instruction is executed, so 4 clocks same as in town if it isn't.
