Icarus Verilog problem (never mind!)
David BetzDavid Betz Posts: 11,472
Edit: Ignore this. It seems my problems had to do with cutting and pasting something from a web page. There must be some non-printing characters in this code that are causing me trouble.
I'm trying to use Icarus Verilog to continue developing a simple CPU that I designed ages ago. After installing iverilog, I tried one of the sample programs and got an error. Is this valid Verilog syntax?
always #5 clk = !clk;
The entire module containing this is:
module test;
  /* Make a reset that pulses once. */
  reg reset = 0;
  initial begin
     # 17 reset = 1;
     # 11 reset = 0;
     # 29 reset = 1;
     # 11 reset = 0;
     # 100 $stop;
  end
  /* Make a regular pulsing clock. */
  reg clk = 0;
  wire [7:0] value;
  counter c1 (value, clk, reset);
  initial
     $monitor("At time %t, value = %h (%0d)",
              $time, value, value);
endmodule // test
I tried commenting out the offending line but then I get an error in the line:
  output [WIDTH-1 : 0] out;
in this module which is also part of the sample:
module counter(out, clk, reset);
  parameter WIDTH = 8;
  input 	       clk, reset;
  reg [WIDTH-1 : 0]   out;
  wire 	       clk, reset;
  always @(posedge clk)
    out <= out + 1;
  always @reset
    if (reset)
      assign out = 0;
    else
      deassign out;
endmodule // counter
I find it odd that the sample code won't compile and run.
