Neato XV LIDAR
In the quest for cheap LIDAR I found there are quite a few <$100 units on ebay. They're used and designed for the Neato robotic vacuum cleaners.
Here is an example - http://www.ebay.com/itm/Neato-BotVac-Lidar-Distance-Sensor-Original-Factory-Part-65-70E-75-80-85-D/253168956088
It looks similar to the unit here - http://www.robotshop.com/en/rplidar-a1m8-360-degree-laser-scanner-development-kit.html
Also appears to be serial - https://xv11hacking.wikispaces.com/LIDAR+Sensor
I'm mostly looking to just play around, if it will fit on an AB maybe drive around. If everything goes well possibly put it on my rover. Does anyone have experience with this LIDAR unit?
  • ercoerco Posts: 19,360
    Amazing price. Did you get one? That exposed rubber belt surprises me. Looks so turntable-ish. Inside any vac is a nasty, dusty, dirty place. I wonder if that's troublesome for the belt.
    Trying to resist.
    Trying.
    "When you make a thing, a thing that is new, it is so complicated making it that it is bound to be ugly. But those that make it after you, they don’t have to worry about making it. And they can make it pretty, and so everybody can like it when others make it after you."
    - Pablo Picasso
  • Yes, it should be here tomorrow. I found one for $60 and the seller was local so I couldn't resist.
    I have some medical grade electronic equipment sanitizer. It is pretty gross to think about where it came from. I'll post some pics when it gets here.
    Nice info & video about using this sensor with LEGO EV3 at http://www.ev3dev.org/docs/tutorials/using-xv11-lidar/
    - Pablo Picasso
  • Thanks, it seems to have gained some popularity with a few platforms over the years. A lot of them mention the need to use PID when controlling the speed of the laser, like you say it gets dirty.
    I'm not entirely sure what to do with it. First I'd like to see if I can use a pair of ESP8266s as a wireless bridge. Then I can put the LIDAR on an AB or Scribbler, do some processing on my PC, and send back commands via XBee.
