Restriction listed for XBee USB Adapter and XBee Pro no longer applies?
In the web page description of the XBee USB Adapter, it has a note that says one should use the XBee SIP Adapter or XBee Adapter board if you plan on using a XBee Pro module.
This note no longer applies, right? From the data sheet for the XBee USB Adapter, it says that the Rev C XBee USB Adapter has a better 3.3V regulator that can supply 400ma to 1A.
Is my understanding correct and the XBee USB Adapter Rev C is now okay for use with the XBee Pro module under continuous transmissions?
regards,radioguykk6
regards,radioguykk6
https://www.parallax.com/product/32480
I would call Parallax tech support to verify that on Monday.
Tech Support: 888-997-8267
https://www.parallax.com/product/80204
