Project board SMD pad — Parallax Forums
I am looking to add a parallel flash memory (SS39LF010) TSOP32 chip...Will that chip fit on the SMD pad of the propeller project board? The data sheet for the chip list .50 BSC???
  • Hal AlbachHal Albach Posts: 747
    edited 2017-05-01 13:50
    Per the data sheet page 26, the TSOP package specifies a distance between the lead rows of 13.8 to 14.2 mm, the maximum distance on the Project Board USB SMD pad is about 8.5 mm.
    Any particular reason you would want to use this device since it appears to require almost 30 I/O pins from the Propeller, which has 32?
