SimpleIDE Project View not persistent.
I'm wondering if I am the only one having this problem. I have gone into Tools>Properties>General and ticked the box that's labelled "View Mode" and then under Tools I can select "Project View" and all is well - until I close SimpleIDE and later open it to continue my current project. Screen comes up back in simple view. Click on tools and the option for setting Project View is missing. Go to Tools>Properties>General and the View Mode box still has the check mark. Go back to Tools and Set Project View still missing. Go back to where the check box for View Mode is, uncheck, and then check the box. Go back to Tools and the Set Project View is now available. I click on that and I'm back into Project View. Work on my project, save it, and close the IDE. Later, start it back up, back to Simple View. Is there any way to keep Project View persistent or am I stuck having to reset the check mark in order to have Project View available?
BTW, I am using version 1.1.0.
There are times when I think the change from .ini files was a leap backwards.
Maybe someone can search through the source code and locate where this code was disabled. Steve (Jazzed) may have added a comment when he did it. If so, it should be easy to fix it.
I also wish it didn't do a bunch of the "auto" inserting things it does, some of which are completely wrong, like often when you have a * on the end of a line and press enter it will tab in and put a * on the line below that.
I know they want a "novice" mode for it, but they should allow pro users to change it's settings and keep those changes between sessions.
Maybe I need to fork it and make NotSoSimpleIDE
If you are serious, I would love to see a NotSoSimpleIDE
