DHB-10 with Raspberry Pi 3 — Parallax Forums
I want to control DHB-10 directly by RaspberryPi3. Is it the right way to connect
"DHB-10 CH1 Black" pin to "RaspPI TX" pin
"DHB-10 CH2 Black" pin to "RaspPI RX" pin
"DHB-10 CH1 White" pin to "RaspPI Ground" pin
"DHB-10 CH2 White" pin to "RaspPI Ground" pin
"DHB-10 CH1 Red" pin to "RaspPI 5V" pin
"DHB-10 CH2 Red" pin to "RaspPI 5V" pin
Do I need resistors etc. in between?
2084 x 619 - 835K
  • Dhb10 black is ground, white is signal tx, rx. Your text is wrong, although the diagram seems to show things correctly.
    Resistors, no. Dhb10 has series resistors built-in, for compatibility with 5v systems.
  • The "5V" pins on the DHB10 aren't connected to anything.
    I'm pretty sure you won't be able to power the Pi from the DHB10.
    Here's the quote from the pdf "Note that the center “R” pin on these headers is not connected."
    There is power output on the encoder headers but I think this a 3.3V supply and intended for low current devices like encoders.
    I'm not absolutely positive, but I'm pretty sure the DHB10 doesn't have a 5V regulator capable of power a Pi. In fact I don't think the board has a 5V regulator at all.
  • Hi
    mkasap, did you succeeded in sending control commands from the Pi to the DHB-10 ?
    On python shell I write :
    import time
    import serial
    ser = serial.Serial(
    port='/dev/ttyAMA0',
    baudrate = 19200,
    parity=serial.PARITY_NONE,
    stopbits=serial.STOPBITS_ONE,
    bytesize=serial.EIGHTBITS,
    timeout=1
    ser.write('GO 50 50')
    On scope I can see there is a correct baud rate and some action, the orange LEDs of the driver stop flashing, but motors aren't turning. any idea ?
    3264 x 1836 - 2M
  • problem solved : "\r"
    so it gives ser.write("GO 50 50 \r")
