BS2 simple serial out works with any pin but not Pin1 - Sout
I need all digital pins P0-P15 for my project. I also need to send a data stream (one direction) to a PIC device. I am using the following basic code to send a test stream. The PIC expects True polarity not inverted:
' {$STAMP BS2}
' {$PBASIC 2.5}
' {$PORT COM12}
Main:
DO
SEROUT 16, 396, ["Hello!", CR] ' send the greeting
PAUSE 100 ' wait 0.1 seconds
LOOP ' repeat forever
END
It doesn't work on Pin 1 however it works fine if I change SEROUT to any other pin.
Just to be sure I looked at the Pin output on my scope which has a UART logic decoder and its all gibberish regardless of settings I try. With the BS2 set for any pin 0-15, the code works perfectly and my scope easily decodes.
Would the line driver on Pin Sout be affecting this? The only wires I have from BS2 to PIC (or scope) are the Sout and Ground.
Any advice appreciated.
Jerry NY2KW
  • 4 Comments sorted by Date Added Votes
  • Phil Pilgrim (PhiPi)Phil Pilgrim (PhiPi) Posts: 21,583
    edited February 2017 Vote Up0Vote Down
    You realize that the RS232 driver on PIN 1 inverts the signal, right? Try 16780 instead of 396 to re-invert it.
    “Perfection is achieved not when there is nothing more to add, but when there is nothing left to take away. -Antoine de Saint-Exupery
  • Yes, thanks. I dont seem to be able to change the signal polarity. The signal pattern looks identical on my scope with either
    SEROUT 16, 396, [string]
    SEROUT 16, 16780, [string].
    My scope to decode does not automatically find the right polarity - i have to set it and I leave it unchanged with both 396 or 16780 and the signal burst is identical.
    Any suggestions?
    TIA
    Jerry
    Just checked, and you're right: the signal does not get inverted with 16780 like you might expect on P16. Soooo ... it looks like you'll have to add an external inverter.
  • The serout inverter on the BS2 is a single PNP prebiased transistor you can find on top of the BS2 module. You could tap/hack into the base of that transistor to find the non-inverted signal.
    Another peculiarity of the Stamp wiring is that the collector of that PNP transistor is connected both to pin 1 of the module, SOUT, and to a 4.7kohm resistor that goes to the SIN pin. The idea is that SOUT will "steal" negative or zero voltage from the SIN pin. If SIN is floating, there is still a path to ground via a pair of 10k resistors and the base of the NPN transistor that inverts the SIN signal. You can see the schematics in the appendix of the Stamp manual.
