Question on garden solar LED light
T Chap
I picked up a garden solar powered LED spot light today that is supposed to turn on at dark and claims 6 hours. A test shows this thing is very bright, a powerful LED for sure. I am using it for a project where I will remove the solar panel from the light and separate the two parts by a few feet. There is a small PCB behind the solar panel, I have not studied in too much detail but I would assume there is resistor in series to the LED, but not sure how much trouble it is to track it down. I'd like to both dim the LED and extend the hours, so would it be assumed that adding a series resistor in line to the LED by some value to get the brightness I want would simultaneously gain some time? Certainly there is circuitry for the light sensor and other parts, but I just wanted to make sure my thinking was correct on adding resistance to the LED would add some amount of longer life.
FWIR of such lights they use a single NiCad battery and thus a SMPS booster to power the White LED.
Replace the "settings resistor" that controls the constant current.
Here is an idea what part may be inside:
http://www.mouser.com/Semiconductors/Driver-ICs/LED-Lighting-Drivers/_/N-7zhqfZscv7?Ns=Pricing|0
Sorry I didn't put the right part
SD42609
