Issue with a Xport of Lantronix — Parallax Forums
Hi, I use a propeller C3 with a Xport of Lantronix. I use manual connection.
For the connection between propeller C3 and the Xport, I use Rx and Tx Pin.
My code is the following :
CON
  _clkmode = xtal1 + pll16x
  _xinfreq = 5_000_000
  Xport_Rx = 0
  Xport_Tx = 2
  Xport_Reset = 4
  Xport_Baud = 9600
  Temps_attente = 5000
VAR
  byte AT_Reponse[150], char
OBJ
  Xport  : "FullDuplexSerial"
  pst : "Parallax Serial Terminal"
Pub main | ptr,a, ptr2
  pst.Start(115200)
  Xport.Start(Xport_Rx, Xport_Tx, 0, Xport_Baud)
  pst.str(String("Commencement",13,10))
'  Reset_Module
  Xport.Str(String("Cwww.smart-wine-cellar.com/80",13))
  Rx(Temps_attente)
  pst.Str(String(13))
  pst.str(String("the request 0: ",9))
  pst.Str(@AT_Reponse)
  pst.Str(String(13))
  waitcnt(clkfreq*2+cnt)
  Xport.Str(String("GET /index.php?Voltage=456789",13,10,13,10))
  Rx(Temps_attente)
  pst.Str(String(13))
  pst.str(String("the request 1: ",9))
  pst.Str(String(13))
PUB Reset_Module
  dira[Xport_Reset]~~
  outa[Xport_Reset]~
  waitcnt(clkfreq/10+cnt)
  outa[Xport_Reset]~~
  waitcnt(clkfreq+cnt)
PUB Rx(timeout)
  Rx_Xport(timeout)
Pub Rx_Xport(timeout) | ptr
    ptr := 0
    repeat
      char := Xport.RxTime(timeout)
      pst.dec(char)
      AT_Reponse[ptr++] := Char
    while (char <> 13)
    AT_Reponse[--ptr] := 0
The response of the request 0 is C for connected and just after I receive HTTP/1.0 408 Request time-out.
When I convert decimal response I don't get the same sentence (the image "conversion" that is attached)
I also attached responses with a baudrate at 9600 and 115200 (image "response with 9600 baudrate" and "response with 115200 baudrate")
I don't understand why I don't get the same response whereas the xport is configured for these baudrate.
When I try to connect me at this URL "www.google.fr" or any other URL, I haven't got responses (see image "www.google.fr").
If anyone has a hint, I would appreciate.
656 x 354 - 23K
888 x 185 - 5K
