Error message from OpenSpin
David Betz
in Propeller 1
I just tried switching from BSTC to OpenSpin for compiling the Spin portions of xbasic and am running into a problem. I get an "undefined symbol 'vm'" error when compiling this code:
Any idea what's going wrong?
CON ' make some vm_interface constants available _MBOX_SIZE = vm#_MBOX_SIZE _STATE_SIZE = vm#_STATE_SIZE FLASH_BASE = vm#FLASH_BASE RAM_BASE = vm#RAM_BASE HUB_BASE = vm#HUB_BASE ' character codes CR = $0d LF = $0a OBJ ser : "FullDuplexSerial" vm : "vm_interface" PUB init_serial(baudrate, rxpin, txpin) ser.start(rxpin, txpin, 0, baudrate) PUB init(mbox, state, code, data, cache_mbox, cache_line_mask) | params[vm#_INIT_SIZE] params[vm#INIT_BASE] := data params[vm#INIT_STATE] := state params[vm#INIT_MBOX] := mbox params[vm#INIT_CACHE_MBOX] := cache_mbox params[vm#INIT_CACHE_MASK] := cache_line_mask vm.start(code, @params)Here is the error:
Propeller Spin/PASM Compiler 'OpenSpin' (c)2012-2016 Parallax Inc. DBA Parallax Semiconductor. Version 1.00.80 Compiled on Sep 29 2016 10:35:12 Compiling... spin/serial_helper.spin |-packet_driver.spin |-vm_runtime.spin vm_runtime.spin(21:73) : error : Undefined symbol Line: PUB init(mbox, state, code, data, cache_mbox, cache_line_mask) | params[vm#_INIT_SIZE] Offending Item: vm
https://github.com/dbetz/xbasic
If you get it from github you should be able to build it with these commands:
Also, can that compile in PropTool? (just vm_runtime.spin and it's dependencies)
I am currently at work, so I can't check/test anything until later tonight.
But as a note, OpenSpin is not BSTC compatible, it's designed to be compatible with Chip's original compiler, but with extensions. BSTC has stuff that is not supported by OpenSpin. Not saying there isn't a possible bug in OpenSpin here, but if you used BSTC extensions then it probably won't work in OpenSpin.
Can you try vm_runtime.spin in PropTool?
In other words, I did this:
This is because during the first pass compile step the sub objects are not compiled yet, so it doesn't have the value defined, and in this case, the local variable information is required to be fully defined in the first pass because the size of the local variables is part of the Symbol information that is created during the first pass.
So this is a case where BSTC is allow something not normally allowed. I looked over the code in OpenSpin, and it would be a significant rework of the compile passes to make this work out.
An alternate solution for your case would be to change the CON section of vm_interface.spin to be an #include file and then use the CON values directly in vm_runtime.spin without the vm# prefix.
If things were reworked to walk all the way down to the leaf child objects to compile them first before trying to first pass compile any parent objects then it could fix this situation, but that is a significant rework. It's possible we might want to do this as part of implementing Spin2. It'll be up to Chip and Jeff.
Chip has got pnut doing all the P2ASM stuff using x86 code evolved from what he had for P1 (that was what I ported to make OpenSpin). So it should be easier to being over his new stuff than it was to do initially.
I know Ken has said in the past that he would like to have the equivalent of OpenSpin for P2 ready at launch of the P2. Not sure if that's still what he wants. I would like it to happen.
The main issue will be time. P2 needs to be done and out ASAP as far as Ken is concerned, and Chip might feel that he can get Spin2 done faster just doing it all in x86 as he has done so far. So there might not be enough time to have OpenSpin2 done in time if Chip does the same x86 thing for everything and I have to port it afterwards. At least it will be done sooner after launch than the P1 version...
I'll be visiting Parallax soon to talk with Jeff and hopefully Ken (if he's not travelling at the time). I'll be visiting Chip at the same time, so some of this will be discussed.
There is some P2 Spin already working in this thread, that targets both P1 and P2, sounds ideal for P2 development.
http://forums.parallax.com/discussion/164187/fastspin-compiler-for-p2
