Problems with PMB-648 GPS
I have a arduino one one paralax 644 GPS card have it connected as follows : yellow pin on input 2 of the arduino and their respective 5v and ground
the code is as follows
#include < SoftwareSerial.h >
SoftwareSerial GpsMod = SoftwareSerial (2.3 ) ;
void setup ()
GpsMod.begin ( 4800 ) ;
Serial.begin ( 9600 ) ;
void loop ()
Serial.print ( GpsMod.read ());
the serial data monitor throws me like this
-1-1-1-1-1-1-1-1-1-1-1-1-1-1-1-1-1-1-136718071716544495752545148465054514448484848464848484844784448484848484648484848446944484448484444484648447744484648447744444848484842526813103671807183654465444944444444444444444444444444444442496913103671808277674449575254514846505451448644484848484648484848447844484848484846484848484469444444485348574954444444784255511310-1-1-1-1-1-1-1-1-1-1
I need help as I do to get the latitude and longitude clearly¿
void setup ()
void loop ()
I'm pretty sure the PMB-648 default baud rate is 9600. Don't know enough about Arduino to know what else may be wrong.
Do you know about GPS sentences?
Edit. I misspoke myself when I said the default baud rate was 9600. Sorry, 4800 is correct.
i tested with that code but the serial monitor goes blank
I'll try my ffriend
