Nokia 5110 LCD works on P2-v10a — Parallax Forums
Cluso99Cluso99 Posts: 18,071
edited 2016-06-23 05:50 in Propeller 2
Here is a program that works with the Nokia 5110 LCD and BeMicroCV-A9.
LCD Plugs directly Pin1..8 --> J1-39..J1-25 (P0,P2,P4,P6,P8,3V3,P10,P12)
Note 1: While the 3v3 is supplying the LCD, the GND is being supplied by P12 and the backlight is supplied by P10 (~6.8mA). The backlight can be enabled by uncommenting the BL=0 line. Without the backlight, current for 3v3 & GND is only ~0.2mA.
Note 2: This is derived from my P1 code so it is not optimised for P2.
Question: What are the new parameters to set the xtal to 80MHz?
  • cgraceycgracey Posts: 14,289
    'CLKSET #$FF' sets 80MHz and this is already done when your program starts using PNut.exe.
