100PSI Transducer Code — Parallax Forums
I'm looking for some code for Basic Stamp 2 (2PX24) for 3 wire 100PSI pressure transducer. Anyone have some guidance?
  • You didn't include much info to go on. Do you have a data sheet for the transducer that you can post?
  • You're right, I did not give much info. Attached is all I have (ebay special). Hopefully this clarifies a bit. Thanks for the fast reply.
  • For easiest use, you'll need an a/d converter. 12-bit a/d are quite common and the LTC1298 is a good , 8-pin unit that will give you 2 selectable channels.
    Parallax used to sell the chip and there is sample code available.
    Cheers
    That graph looks similar to the one for some pressure transducers I'm using though mine are rated to 3,000 PSI and the code I wrote to read the transducers is all PASM. Is there a label on the transducer giving a part number, model number, or manufacturer name?
    Since the output is an analog voltage you will need to convert that to a number. That can be done using an ADC chip, two propeller pins as a sigma/delta ADC, or a V-F chip.
    If you go the ADC route an 8 bits is fine since the transducer accuracy is only 1.5%, although a higher resolution (10, 12, or more bits) would also work. Best to select one that has a driver in the OBEX.
    For a V-F chip you can use a single pin to measure the frequency.
    Once you have a voltage value converting it to pressure is simple.
  • Providing the transducer reading directly to an ADC might not work very well in all cases. I needed to use an amplifier between the sensor and the ADC to get good results for my application. You're looking for something called an 'instrumentation amplifier' but I can't remember the exact part number or the manufacturer. The one that I used was advertised as being unity gain stable and has proven to be so.
