What is the maximum possible throughput of SPI on the Prop?
Mickster
in Propeller 1
IIRC @FriedV was achieving 1MHz but believed he could push it beyond 2MHz, using PropBASIC. I am looking at a clock speed of 96MHz.
This works well for transmit, for receiving 12 Mb/s is more safe (but you asked for the maximum).
Andy
Achieving this fine phasing control without upsetting the SPI bus might be a fun experiment.
Yeah but I'm thinking tha sometimes SPI needs short transactions (less than 32bits, or even 16 bits). The shorter the transactions become, the more problematic the counter-manipulation overheads will be.
Yes, there are many trade-offs, and to complicate things more, "SPI" is not a formal standard.
Strictly, SPI is duplex with data-in at the same time as data-out, but in most real memory uses, you can speed things up with a simplex design.
Then, there is QuadSPI, which just about all FLASH parts now support, and certainly is the main-volume driver.
the bits,
of video driving the SCLK and MOSI. 2 video clocks are needed per bit output. This means having to
duplicate and spread the bits apart to send them, but the application I was working with was painting
pixels into a SPI TFT chip where to fill a rectangle you have to send the same pixel data repeatedly
so the cost of pre-processing the data is spread out across many bytes sent.
To be more precise I was encoding the byte abcdefgh as
a1a0b1b0c1c0d1d0e1e0f1f0g1g0h1h0, ie alternating data/clock and every other clock is inverted.
Can't recall the max video clock rate, but the max SPI clock will be 1/2 of that by this method.
IIRC max video clock is 128MHz so max spi clock would be 64MHz, although I doubt that even a cog pasm program could sustain that data rate for more than a few bytes of data.
will break things. For really fast you have to use the video outputs for all the signals I think
This is the speed table, SPI (i2c can go to std 3.4MB/s, and can be set to 6.66Mbit/s)
QuadSPI is available in master only. Highest slave CLK is 20MHz
WAITPIN can be used on CS# and then CLK to sync a P1 to the master clk.
For SW based Quad SPI, I think you need a rotate and output, plus the clock.
I figure highest speed without SW CLK (timer CLK) is 10MHz and with SW clk is 5MHz
In one burst design, with a small 8b MCU, I allocate first clocks for WRITE, then some dummy/turnaround clocks, and then some reply clocks.
You can also shift the window, to allow one FT4222 master to send to multiple slaves (can be separate MCU, or separate COG) in the same packet.
FT4222 -> MCU is ok with CLK sync, & the skip clocks can be managed in 8b MCU with a Reload-Timer with external CLK and TF0 polling.
That's not so easy on P1, as you cannot wait on a timer, but you can externally clock it, so it seems a =\_ CLK, and a 2 line poll-timer loop can coarse sync, (Skip-1) and then a WAITPIN pair can sync on the final edge, for replies.
Such (Sync + R or W) on paper can unroll to around 5MHz/nibble, which is a decent ~20Mbit burst speed.
( a AUP1G80 from the FT4222 12MHz can give a 6MHz P1 clk, and that is 19.2 SysCLKs at 5MHz , 25.6 SysCLKs at 3.75MHz, 32 SysCLKS at 3MHz )
Has anyone done an i2c Master or Slave on P1 to 3.4MHz ? Seems doable ?
The counter runs continuously in PLL single-ended (or differential) mode. The PLL output is the clock. The PLL output also feeds the video generator. It seems to work fine with the counter in PLL output mode. The video generator outputs the data and chip select. I also use it to force the clock output high when not sending. It looks better on the scope, but may not be required. The video generator is in 1 bit mode. The chip select and clock masking are generated with a separate waitvid using different "colors."
The writes to OUTA and VCFG are to keep the outputs in a known state without having to keep the video generator constantly fed.
What clock speeds did you achieve with that, and what was it connected to ?
Video modes are master only, (one bit?) and also can only write (not duplex, no read)
Yes, master only, write only. Never tried it with a device, just the oscilloscope. It seems to work at 160MHz. 2 data bits should be possible. Could also do 8 bits.
The plots show a 32 bit transfer at 20 MHz. The last one is at 100MHz. It's a 70MHz oscilloscope so the 160MHz test didn't look that good.
Nice looking plots.
The FT4222H I am looking at, can support 20MHz SCK in slave mode, so this example could work well with that for fast, one way P1 -> PC.
Where PC-> P1 is needed the P1 can lower the clock easily, since P1 generates the clock. GPIO lines can set direction, at a more modest speed.
What is the sustainable data rate ? (ie how much housekeeping overhead is involved)
Scope shows I think 417k*32 = 13.344Mb/s sustained, but that looks like a repeating payload ?
A couple of possible benchmarks
a) Read (say) 8-16-24 pins, and stream to PC, continually.
b) use WAITPIN and Counter, to send a 24b(pin)+32b(dT) packet, of PinPatterns + TimeStamp.
An option of 8b(pin) and 24b(dT) would have a data-send time of 1.6us at 20MHz, so that sets a ceiling on peak change-rate supported, but maybe a simple FIFO can allow glitch capture lower than 1.6us ?
