Debug Terminal Problem — Parallax Forums
Would somebody please explain how I can modify my program so that when any keys input from keyboard other than the umbers 0 through 9 are pressed the program will type "invalid entry" , "try again". Below is my program , Thanks.
' {$STAMP BS2}
' {$PBASIC 2.5}
'4 color leds
counter VAR Word
repeat VAR Nib
led VAR Nib
lines VAR Byte
blue CON 0
green CON 1
yellow CON 2
red CON 3
Main:
GOSUB Terminal
led=blue
DEBUG HOME,"blue led" 'pin 1 blue led
GOSUB timing
led=green 'pin 2 green led
DEBUG HOME,"green led"
GOSUB timing
led=yellow 'pin 3 yellow led
DEBUG HOME,"yellow led"
GOSUB timing
led=red 'pin 4 red led
DEBUG HOME,"red led"
GOSUB timing
GOTO main
timing:
FOR repeat = 1 TO 2
FOR counter = 0 TO 500 STEP 20
PULSOUT led, counter
PAUSE 10
NEXT
FOR counter = 500 TO 0 STEP 20
PAUSE 10
NEXT
NEXT
Terminal:
DEBUG CLS
DEBUG "What color led's?", CR
DEBUG "1=Blue,2=Green,3=Yellow,4=Red", CR
DEBUGIN DEC1 lines
IF lines = 1 THEN
DEBUG CLS,CR, CR
GOSUB blueled
ENDIF
IF lines = 2 THEN
DEBUG CLS,CR, CR
GOSUB greenled
ENDIF
IF lines = 3 THEN
DEBUG CLS,CR, CR
GOSUB yellowled
ENDIF
IF lines = 4 THEN
DEBUG CLS,CR, CR
GOSUB redled
ELSE
ENDIF
IF (lines < 1) OR (lines > 4) THEN
GOSUB invalid
ENDIF
GOSUB invalid
PAUSE 2000
GOTO Terminal
blueled:
led=blue 'pin 1 blue led
GOSUB timing
RETURN
greenled:
GOSUB timing
RETURN
yellowled:
GOSUB timing
RETURN
redled:
DEBUG CLS
led=red 'pin 4red led
GOSUB timing
RETURN
invalid:
DEBUG CLS, "Invalid entry!",CR
DEBUG "Try again"
RETURN
  • Rather than,
    DEBUGIN DEC1 lines
    try
    DEBUGIN lines
    IF lines < "1" OR lines > "4" THEN GOSUB invalid
    That is, treat the options as single ascii characters rather than as DECimal values.
    Note on program structure: take a look at the SELECT:CASE instructions for more compact branching through the options.
  • I added another subroutine called servo1 and modified your suggestion and the program will not run properly. Debug terminal loops asking for inputs and no matter what key is pressed displays " invalid entry", "try again".
  • Here is my code.
    ' {$STAMP BS2}
    ' {$PBASIC 2.5}
    ' fireflyled4
    counter VAR Word
    repeat VAR Nib
    led VAR Nib
    lines VAR Word
    blue CON 0
    green CON 1
    yellow CON 2
    red CON 3
    Main:
    GOSUB Terminal
    led=blue 'pin 0 blue led
    GOSUB timing
    led=green 'pin 1 green led
    GOSUB timing
    led=yellow 'pin 2 yellow led
    GOSUB timing
    led=red 'pin 3 red led
    GOSUB timing
    GOTO main
    timing:
    FOR repeat = 1 TO 2
    PAUSE 10
    NEXT
    PAUSE 10
    NEXT
    NEXT
    Terminal:
    DEBUG CLS
    DEBUG HOME, "What program numbers? Blinking color led's twice",CR
    DEBUG "1=Blue,2=Green,3=Yellow,4=Red",CR
    DEBUG "5=servo control demo"
    'DEBUGIN DEC1 lines
    DEBUGIN lines
    IF lines < "1" OR lines > "5" THEN
    GOSUB invalid
    'ENDIF
    'ENDIF
    'GOSUB invalid
    'PAUSE 2000
    'GOTO Terminal
    IF lines = 1 THEN
    DEBUG CLS,CR, CR
    GOSUB blueled
    ENDIF
    IF lines = 2 THEN
    DEBUG CLS,CR, CR
    GOSUB greenled
    ENDIF
    IF lines = 3 THEN
    DEBUG CLS,CR, CR
    GOSUB yellowled
    ENDIF
    IF lines = 4 THEN
    DEBUG CLS,CR, CR
    GOSUB redled
    ELSE
    ENDIF
    IF lines = 5 THEN
    DEBUG CLS,CR, CR
    GOSUB servo1
    'ELSE
    ENDIF
    ENDIF
    GOTO terminal
    'IF (lines < 1) OR (lines > 4) THEN
    'IF lines < "1" OR lines > "4" THEN
    'GOSUB invalid
    'ENDIF
    'GOSUB invalid
    'PAUSE 2000
    'GOTO Terminal
    blueled:
    GOSUB timing
    RETURN
    greenled:
    GOSUB timing
    RETURN
    yellowled:
    GOSUB timing
    RETURN
    redled:
    DEBUG CLS
    GOSUB timing
    RETURN
    invalid:
    DEBUG "Try again"
    RETURN
    servo1:
    DEBUG "Pulse width increment by 8", CR 'rotate pointer ccw to 180deg, the rotate to 0 deg.
    'FOR repeat = 1 TO 2
    FOR counter = 1500 TO 100 STEP 8
    HIGH red
    IF counter = 100 THEN HIGH blue
    LOW red
    PULSOUT 14, counter
    'ELSE HIGH blue
    ' ENDIF
    PAUSE 7
    DEBUG DEC5 counter, CR, CRSRUP
    ' ENDIF
    NEXT
    'ENDIF
    'NEXT
    RETURN
    I'm going to guess that because you're not using code tags, the formatting is getting all messed up. With that and all the commented out lines it's really hard to follow the flow of your program. I would recommend using code tags or attaching the program as a file so it is easier to read.
  • tomcrawfordtomcrawford Posts: 1,126
    edited 2016-04-22 17:17
    I think you may have commented out one too many endif's right after you test for < "1" or > "4".
    Also, this is a good time to read about select/case.
      DEBUGIN lines
      SELECT lines
         CASE "1"
            DEBUG CLS,CR, CR
            GOSUB blueled
         CASE "2"
            DEBUG CLS, CR, CR
            GOSUB greenled
          and so-on for "3" and "4"
         CASE ELSE
             GOSUB invalid
        ENDSELECT
  • Thanks Tomcrawford. With your suggestion adding select/case the program works fine and I I plan to use it often.
    ' {$STAMP BS2}
    ' {$PBASIC 2.5}
    ' fireflyled4
    [b][/b]    counter VAR Word
        repeat  VAR Nib
        led     VAR Nib
        lines   VAR Word
        blue    CON 0
        green   CON 1
        yellow  CON 2
        red     CON 3
     Main:
      GOSUB Terminal
      GOSUB timing
      GOSUB timing
      GOSUB timing
      GOSUB timing
     GOTO main
     timing:
     FOR repeat =  1 TO 2
         PAUSE 10
       NEXT
         PAUSE 10
      NEXT
     NEXT
     Terminal:
      DEBUG CLS
      DEBUG HOME, "What program numbers?",CR
        DEBUGIN lines
        SELECT lines
        CASE "1"
          DEBUG CLS,CR,CR
          GOSUB blueled
        CASE "2"
          DEBUG CLS,CR, CR
          GOSUB greenled
        CASE "3"
          DEBUG CLS,CR, CR
          GOSUB yellowled
        CASE "4"
          DEBUG CLS,CR, CR
          GOSUB redled
        CASE "5"
          DEBUG CLS,CR, CR
          GOSUB servo1
        CASE ELSE
          GOSUB invalid
        ENDSELECT
        GOSUB invalid
        ENDIF
        GOTO terminal
     blueled:
      GOSUB timing
      RETURN
     greenled:
      GOSUB timing
      RETURN
     yellowled:
      GOSUB timing
      RETURN
     redled:
      DEBUG CLS
      GOSUB timing
      RETURN
     invalid:
      DEBUG CLS
      DEBUG  "Invalid entry!"
      DEBUG "Try again"
      PAUSE 1000
      RETURN
    servo1:
      HIGH green
       LOW red
      PULSOUT 14, counter
      PAUSE 7
      NEXT
      PAUSE 500
      LOW blue
      LOW green
      RETURN
      DEBUGIN lines
      SELECT lines
         CASE "1"
            DEBUG CLS,CR, CR
            GOSUB blueled
         CASE "2"
            DEBUG CLS, CR, CR
            GOSUB greenled
         CASE ELSE
             GOSUB invalid
        ENDSELECT
