Emic2 arduino Serial out Codes
Hello i have an Emic2 and it works great sounds great,
I like to have the Codes the Emic2 makes of text input so i can
feed this to another chip, via an Arduino.
I like to use the TTS command from the Emic2,
Is there a way to make the Emic2 spit this Codes out.
Thanks in advance, Dian from the Netherlands
Your other post has been deleted because it is against forum rules to double post.
Have you checked all the Data sheets?
https://www.parallax.com/product/30016
http://www.grandideastudio.com/portfolio/emic-2-text-to-speech-module/
I see nothing about that in the manual, only see the pins mentioned in the
datasheet,
Thanks, Dian
