Production of a printed circuit boards, using diode laser installed on a 3D printer.
We made a video how to make a printed circuit boards using diode laser installed on a 3D printer (or you can put on any CNC mill).
The idea is that you cover copper board with a vinyl film and then remove it with a diode laser.
The simply put into Ferrum chloride.
If anyone has an idea how to make edges more accurate, please let us know.
A much better -- and safer -- choice would be either Kapton film or polyester film.
Another source of concern is eye safety relating to the reflection of the laser beam from the copper substrate. Your 3D printer has no optical shielding around it, and retinal damage could occur from watching the unit operate.
I made a better board in 1973 drawing it by hand with a etch resist felt tip pen. Probably quicker as well for a simple one off prototype. Certainly cheaper than getting a 3D printer.
One can do better now a days with a laser printer and the toner transfer technique.
Sorry to be so negative. But, well, reality is like that.
We can buy PCBs with UV sensitive etch resist coatings. So if you can get your laser to harden up that to the desired pattern you will probably get a lot more resolution.
Finally, any miss-step and the laser can cook / cut you hand just as easily as it does the copper PCB. Operating the laser CNC / 3D printer with out any guards is beyond crazy and gives other people the false impression it is safe.
