using F32 in multiple objects, then multiple interpreter cogs
PaulRowntree
Hi! It has been several years since I last worked with the prop, but some home and work projects have come up that have brought me back. But oh so rusty!
I am working on an I2C interfaced IMU board from Pololu, using Mike Green's I2C drivers. Everything is working well. Now I want to add the trig bits, using floating point.
First off, is F32 v1.6 the current code that people are using?
Second, if I want to use floating point in the top level spin code and in the IMU object that I have written (both running on the same SPIN interpreter cog), do I just declare that they both use F32, but only start it from the top level code?
Almost Lastly, if/when I want the IMU code to run autonomously in the background, do I need 2 F32 cogs, one for each interpreter?
Lastly, can I run a background cog code that interfaces the I2C, but in the same IMU object have spin code that gets called from the top level SPIN, and therefore only uses a single instance of F32?
It's taking some doing to clear the cobwebs from under these grey hairs ... it is still a pretty cool chip.
Cheers, and thanks in advance for your help !
pr
pr
2) I think you'll need to pass some address between the two F32 objects to get both hooked to the same F32 assembly cog. (i.e. you'd start one, and make an init() function for the other)
3) Yes, you'll need two F32 cogs, or a lock to arbitrate sharing. Another approach would be to modify the F32 command interpreter so it can accept commands from two sources as I'm pretty sure the Spin wrapper is the biggest bottle-neck for F32 right now.
4) if the top-level spin code doesn't care about speed, use FME.spin for it's floating point. Has all the functions of F32, but all in Spin. (link in my sig)
JasonDorie, I don't know what the 'stream processor' is; no ref to it in F32_1_6, nothing that I can see in Obex. it sounds useful ... can you give any details on what it is and how to find it?
Thanks!
The F32 object in the Elev8-FC github implements a stream processor, but you have to lose a couple commands to create space for it. I believe the Float32 object has it built in already.
