Counter question — Parallax Forums
Counter question
I was looking at the instruction set and "ADDCT1" was under hub instructions. I wanted to clarify if there are 3 counters per COG or 3 counters in the hub, so only 3 counters for the chip?
  • SeairthSeairth Posts: 2,474
    edited 2015-11-17 07:14
    Three per cog. Those are not hub instructions.
  • evanhevanh Posts: 15,192
    They're actually equality compares - compared against the system counter, which is considered to be a Hub item.
    I think. :)
    edited 2015-11-17 11:48
    That is true. However, the counter registers themselves are located in each cog and do not require hub alignment to be updated.
    It makes me wonder, though... would there be a value in having one (or more) global timers as well? One cog would update the timer and other cogs would use events (or polling).
    edited 2015-11-17 11:01
    True, it's not HubRAM access aligned. I think it's just intended as documentation grouping is all.
