Serial output - Is there a better way to do this? — Parallax Forums
Jeff HaasJeff Haas Posts: 431
edited 2015-10-18 00:18 in Propeller 1
I'm learning Spin having moved over from PBasic, and I've got one of the inexpensive Catalex MP3 players mentioned in another thread. It works fine with this code:
 Catalex mp3 board sound test
 10/17/2015
 One MP3 in a folder named 01 on MicroSD card.
CON
  _clkmode = xtal1 + pll16x         ' Crystal and PLL settings.
  _xinfreq = 5_000_000              ' 5 MHz crystal x 16 = 80 MHz
OBJ
  Serial : "FullDuplexSerial"
PUB Go
  serial.start(2, 3, %0000, 9_600)
  Serial.Tx($7E)                  ' Init the Catalex MP3 player
  Serial.Tx($FF)
  Serial.Tx($06)
  Serial.Tx($0C)
  Serial.Tx($00)
  Serial.Tx($00)
  Serial.Tx($00)
  Serial.Tx($EF)
  waitcnt(clkfreq + cnt)            ' Wait 1 second
  Serial.Tx($7E)                  ' Select TF socket
  Serial.Tx($FF)
  Serial.Tx($06)
  Serial.Tx($09)
  Serial.Tx($00)
  Serial.Tx($00)
  Serial.Tx($02)
  Serial.Tx($EF)
  Serial.Tx($7E)                    ' Set volume to 15
  Serial.Tx($FF)
  Serial.Tx($06)
  Serial.Tx($06)
  Serial.Tx($00)
  Serial.Tx($00)
  Serial.Tx($0F)
  Serial.Tx($EF)
  Serial.Tx($7E)                    ' Play song 1 in folder 1
  Serial.Tx($FF)
  Serial.Tx($06)
  Serial.Tx($0F)
  Serial.Tx($00)
  Serial.Tx($01)
  Serial.Tx($01)
  Serial.Tx($EF)
However, I can't figure out how to represent all the serial commands on a single line. It's easy on the BS2:
SEROUT MP3, 84, [$7E,$FF,$06,$09,$00,$00,$02,$EF]   'Select TF socket
What's the best way to do this? I tried out the other commands in FullDuplexSerial but couldn't get them to work. And I've looked through lots of the other serial methods in the OBEX but can't find what I want.
  • AribaAriba Posts: 2,694
    The str methode with a string() pseudo function does something like that, but it can not handle $00 values, because these signals the end of the string.
    One way to do it is with byte arrays in a DAT section:
    PUB Go
      CatalexCmd(@MP3Init)
      CatalexCmd(@Volume)    'set volume to 15
      Volume[6] := 3
      CatalexCmd(@Volume)    'set volume to 3
    PRI CatalexCmd(pntr) : i
      repeat i from 0 to 7
        Serial.Tx(byte[pntr][i])
    DAT
    MP3Init   byte  $7E,$FF,$06,$0C,$00,$00,$00,$EF
    Volume    byte  $7E,$FF,$06,$06,$00,$00,$0F,$EF
    As you see, you can also modify the byte data very easy before you send a command.
    Andy
  • Andy,
    Thanks! That was just what I needed. I'm still getting my head around the whole object and method-oriented way of doing things.
    FYI, after some experimentation, for anyone else interested in using the Catalex board, the MP3Init sequence is not needed. You just need these:
    DAT
    SelectTF      byte $7E,$FF,$06,$09,$00,$00,$02,$EF  'Select TF socket on Catalex
    Volume        byte $7E,$FF,$06,$06,$00,$00,$0F,$EF  'Set volume to 15
    PlayMP3       byte $7E,$FF,$06,$0F,$00,$01,$01,$EF  'Play song 1 in folder 1
    Then you can select both the MP3 to play and the folder using these commands, as Andy shows above:
    PlayMP3[5] := 2          'Select SD card folder
    PlayMP3[6] := 1          'Select mp3 in folder
    Jeff
  • JonnyMacJonnyMac Posts: 9,515
    edited 2015-10-18 14:13
    Piggy-backing on Andy's examples, I would suggest creating simple method calls so that you only have to look into the details of the device once. For example:
    pub set_volume(v)
      Volume[6] := 0 #> v <# MAX_VOL
      CatalexCmd(@Volume)
  • Jeff Haas wrote: »
     10/17/2015
    CON
    OBJ
    PUB Go
      Serial.Tx($FF)
      Serial.Tx($06)
      Serial.Tx($0C)
      Serial.Tx($00)
      Serial.Tx($00)
      Serial.Tx($00)
      Serial.Tx($EF)
      Serial.Tx($FF)
      Serial.Tx($06)
      Serial.Tx($09)
      Serial.Tx($00)
      Serial.Tx($00)
      Serial.Tx($02)
      Serial.Tx($EF)
      Serial.Tx($FF)
      Serial.Tx($06)
      Serial.Tx($06)
      Serial.Tx($00)
      Serial.Tx($00)
      Serial.Tx($0F)
      Serial.Tx($EF)
      Serial.Tx($FF)
      Serial.Tx($06)
      Serial.Tx($0F)
      Serial.Tx($00)
      Serial.Tx($01)
      Serial.Tx($01)
      Serial.Tx($EF)
    which thread are you referring? Just curious
  • Shawn Lowe wrote: »
    Could be this one:
    http://forums.parallax.com/discussion/161245/erco-here-s-the-cheap-mp3-modules
  • After looking at the docs I knocked up a little object for that player. I don't tend to post untested code (I don't have a player yet), but I'm confident this should be safe to try.
    Since I don't have one and I wanted others to be able to reference the Schmarschmino demos the vendor provides, I used their named constants. Once I get a player and understand what each thing does, I may rename things. Note, too, that all of the demos show no feedback from the player and a baud rate of 9600. This can be done with a single pin and a method; no serial cog is required.
  • It's pretty easy to create a routine that works like STR but allows for a zero byte:
    PUB txStrEsc(str) | temp
      repeat while temp := BYTE[ str++ ]  ' repeat as long as byte isn't zero
        if temp == $7F  ' escape byte is $7F
          if (temp := BYTE[ str++ ]) => $80  ' get escaped byte value
            Serial.Tx(temp & $7F)  ' strip high order bit for transmission
          else  ' A $7F must not be followed by a byte less than $80
            quit  ' This is so a string ending with $7F will terminate properly
        else
          Serial.Tx(temp)
    To transmit the example shown for the BS2, do:
    txStrEsc( string( $7E, $FF, $06, $09, $7F, $80, $7F, $80, $02, $EF ) )
    A $7F is followed by the byte to be sent with its high order bit set. To send $00, use $7F,$80. To send $7F, use $7F,$FF. There's a check for the case where a $7F is the last byte in a string.
    edited 2015-10-18 18:08
    For this common situation add a method to your serial object. Enter with a pointer to the string and the count of bytes.
    PUB StrN(stringptr,nchar)
    '' Send counted string
      repeat nchar
        tx(byte[stringptr++])
    Then as Jon suggests, in the application give each function a meaningful name that calls the generic StrN. Or, simply give each string a name that reveals its function.
    edited 2015-10-18 18:15
    Actually, looking at Jon's program, I see that the device command set has several constant elements and two variable elements, and Jon has encapsulated that in a method,
    send_command(cmd, value)
    Very much on target, as usual.
    edited 2015-10-18 19:12
    To be fair, I simply ported code from the vendor's Schmarschmino demo. Here's the original.
    void sendCommand(int8_t command, int16_t dat)
      delay(20);
      Send_buf[0] = 0x7e; //
      Send_buf[1] = 0xff; //
      Send_buf[2] = 0x06; //
      Send_buf[3] = command; //
      Send_buf[4] = 0x00;//
      Send_buf[5] = (int8_t)(dat >> 8);//datah
      Send_buf[6] = (int8_t)(dat); //datal
      Send_buf[7] = 0xef; //
      for(uint8_t i=0; i<8; i++)//
        mySerial.write(Send_buf[i]) ;
    I didn't think it was necessary to stick the bytes into a buffer before sending -- at 9600 baud a few microseconds here and there between bytes should be fine.
    pri send_command(cmd, value)
      delay(20)
      tx($7E)
      tx($FF)
      tx($06)
      tx(cmd)
      tx($00)
      tx(value.byte[1])
      tx(value.byte[0])
      tx($EF)
    pri delay(ms) | t
      t := cnt
      repeat ms
        waitcnt(t += clkfreq/1000)
    pri tx(b) | t                                           ' borrowed from Simple Serial
    '' True mode output of byte b
      b := (b | $FF00) << 2                                 ' add stop bit(s), start bit
      t := cnt                                              ' sync bit timer
      repeat 10                                             ' start + 8 bits + stop
        waitcnt(t += bitticks)                              ' hold for bit timing
        outa[txp] := b >>= 1                                ' output next bit
    That demo commands disable response from the device so I kept it to one pin. Since coms is the very tame speed of 9600 baud, I was able to borrow (with some clean-up) serial output from Simple Serial.
  • I tried out JonnyMac's port of the C code, by using jm_debounce to read the buttons and then send commands to jm_catalex_mp3. It works!
    I set up six buttons as the schematic in the original file here in the OBEX shows. Those aren't shown below because some characters don't display properly in the forum.
    ''   File....... jm_debounce_catalex_mp3.spin
    ''   Purpose.... Debounces inputs, sends commands to Catalex MP3 player
    ''   Updated.... 20 OCT 2015
    con
    con
      BTN_UP   = %000001 << 18                                       ' for JM LCD UI board
      BTN_DN   = %000010 << 18
      BTN_LF   = %000100 << 18
      BTN_RT   = %001000 << 18
      BTN_OK   = %010000 << 18
      BTN_ESC  = %100000 << 18
      BTN_MASK = BTN_UP | BTN_DN | BTN_RT | BTN_LF | BTN_OK | BTN_ESC
      ACT_HI   = 1
      ACT_LO   = 0
    obj
      btns : "jm_debounce"
      catalex  : "jm_catalex_mp3"
    var
    pub main | b
      catalex.setup(3)                            ' TX pin to Catalex is pin 3
      btns.init(BTN_MASK, 25, ACT_HI)
      repeat
        if btns.getbits(BTN_ESC)
          catalex.stop
        b := btns.getbits(BTN_MASK) & !BTN_ESC                      ' all but Esc
        case b
          BTN_UP : catalex.play_from_folder(2,1)               ' LCD commands in original replaced with these commands for testing
          BTN_DN : catalex.next_song
          BTN_LF : catalex.previous_song
          BTN_RT : catalex.volume_up
          BTN_OK : catalex.volume_down
        waitcnt(clkfreq / 10 + cnt)
