Edge interrupts not working? — Parallax Forums
dat
		orgh	0
		org
		setb	dirb, #0	'make that pin an output
		setb	dirb, #1
		waitx	##25_000_000	'wait 1/2 second for INB to figure itself out
		setedg	#%0_10_1_11011	'falling edge on inb[27]
		mov	ijmp1, #isr
		setint1 #%010		'edge-triggered event
'loop		waitint
'		jmp	@loop
loop		waitedg
		notb	outb, #1	'toggle LED
		waitx	##5_000_000	'wait 1/10th of a second for lazy debounce
		polledg			'clear
		jmp	@loop		'repeat
isr		notb	outb, #0	'toggle LED
		polledg			'clear
		reti1
Given the above code, the ISR never executes. WAITEDG and POLLEDG are working, though.
  • cgraceycgracey Posts: 14,133
    Do 'SETINT1 #3'.
    I'm documenting this today.
    wire [7:0] ints		= {	fbw_event,	// interrupt sources
    				xro_event,
    				wrl_event,
    				rdl_event,
    				edg_event,
    				pat_event,
    				cnt_event,
    				1'b0 };
  • That worked. Thanks.
    (note: yeah, I knew you were documenting it. I was just being impatient. :) )
    edited 2015-10-13 01:08
    Seairth wrote: »
    Actually, I haven't even gotten back to the documentation today, yet, because I've been working on the assembler syntax.
