18200 h-bridge question
Mickster
I would like to drive a 2-coil solenoid valve using the 18200. The two solenoids, A & B, oppose each other.
I am thinking that the following should work:
Output #1 from 18200 to the +ve terminal of the DC solenoid coil "A" and the -ve coil terminal to ground.
Output #2 from 18200 to the +ve terminal of the DC solenoid coil "B" and the -ve coil terminal to ground.
The objective being that a change of direction on the amplifier direction pin will switch from A to B etc.
Is there any reason why this won't work?
Cheers.
Mickster
Cheers.
Mickster
