PASM gurus - bit matrix transform challenge — Parallax Forums
In COG I have a bit-matrix 32*8 = 8 consecutive longs
I want to populate them with data from a 32 byte HUB array
in a way, that each byte fills the same bit position in the COG bit-matrix
so first byte ends up in bit position 0 of all 8 longs
and 32nd byte ends up in bit position 31 of all longs
any neat tricks out there?
thanks
MJB
  • No tricks, just 8 pairs of shifts in a loop:
    dat
                         mov     Ptr,par                ' assuming byte vector is a parameter
                         mov     Count,#8
    byte_loop       rdbyte  T,Ptr                   ' read a byte
                          add      Ptr,#1                 ' increment the pointer
                          shr     T,#1    wc              ' C := bit 0
                          rcr     T,M0
                          shr     T,#1    wc              ' C := bit 1
                          rcr     T,M1
                          shr     T,#1    wc              ' C := bit 2
                          rcr     T,M2
                          shr     T,#1    wc              ' C := bit 3
                          rcr     T,M3
                          shr     T,#1    wc              ' C := bit 4
                          rcr     T,M4
                          shr     T,#1    wc              ' C := bit 5
                          rcr     T,M5
                          shr     T,#1    wc              ' C := bit 6
                          rcr     T,M6
                          shr     T,#1    wc              ' C := bit 7
                          rcr     T,M7
                          djnz    Count,#byte_loop
    Done                                                    ' more code here
    Ptr                res     1
    Count           res     1
    T                  res     1
    M0               res     1
    M1               res     1
    M2               res     1
    M3               res     1
    M4               res     1
    M5               res     1
    M6               res     1
    M7               res     1
                        fit
  • MJBMJB Posts: 1,235
    edited 2015-08-30 06:26
    ksltd wrote: »
    dat
                         mov     Count,#8
                          rcr     T,M0
                          rcr     T,M1
                          rcr     T,M2
                          rcr     T,M3
                          rcr     T,M4
                          rcr     T,M5
                          rcr     T,M6
                          rcr     T,M7
    Ptr                res     1
    Count           res     1
    T                  res     1
    M0               res     1
    M1               res     1
    M2               res     1
    M3               res     1
    M4               res     1
    M5               res     1
    M6               res     1
    M7               res     1
                        fit
    thanks
    good - was thinking of using MUXC to set the values - but shifting RCR in is good thought ... saves the extra mask and shifting it
    muxing would give some flexibility if I wanted to insert the byte at random positions into the matrix.
    shouldn't your
                          rcr     T,M0
    be
                          rcr     M0,#1
    ?? or what do I miss?
    dat
                         mov     Count,#8
                         mov     mymask,#1
                          muxc    M0,mymask
                          muxc    M1,mymask
                          muxc    M2,mymask
                          muxc    M3,mymask
                          muxc    M4,mymask
                          muxc    M5,mymask
                          muxc    M6,mymask
                          muxc    M7,mymask
                          shl     mymask,#1               ' go for next destination position
    Ptr             res     1
    Count           res     1
    T               res     1
    M0               res     1
    M1               res     1
    M2               res     1
    M3               res     1
    M4               res     1
    M5               res     1
    M6               res     1
    M7               res     1
    mymask           res     1
                        fit
  • ugh ... yes. All those RCRs are, as you point out, wrong.
  • ksltd wrote: »
    You could do it with:
    rcl    M0, #1
    After 32 bytes, the bits would be in the correct position. The muxc solution is elegant, though. That's one of those instructions that I never use, but probably should be. :)
  • Ummm ... yes ... that's what he pointed out.
  • Mjb,
    You have no initial value for your mask. And the mask just isn't necessary.
  • ksltd wrote: »
    No, I was saying your approach was good. It just needed RCL instead of RCR.
