P1 Camera Identity and Vital Signs — Parallax Forums
rjo__rjo__ Posts: 2,114
edited 2015-08-01 15:46 in Propeller 1
This is a utility that will automatically identify Omnivision camera modules... most of the ones available on Ebay ($4-$30).  And it will give you camera vitals signs:  frames per second, pixel clock frequency, pixels per frame, lines per frame, pixel clocks per line, VSync and Hsync polarity, etc.  On the Propeller1-2-3 or DE2-115, the same hardware is being used to implement a multiple camera setup.  That work will be posted as it is completed.
This entire thread is a work in progress.  I'm going to post the code and pictures ... worth 12000 words.  Time permitting, I will go back and write it up properly.
This project requires:
                                 1) Propeller Activity Board (although just about any board Parallax makes could be used)
                                 2) An EDU card... nicely made, very flexible... order a dozen of them.
                                    In a pinch, the PAB breadboard can be used.
                                 3) A 2x20 long legged, female header
                                 4) Garden Shears
89769bbe33424dd9c9f261198d6740.zip
