Arduino uno, adafruit motor shield and colorPAL
Hello, I am building a robot using arduino uno, a motor shield and the sensor colorPAL. I've got colorPAL demo code from http://learn.parallax.com/colorpal-arduino-demo, and it worked properly. Then I made a code for the motors, and robot went forward. All ok till now. Then I wrote an if statement, using data obtained from colorPAL. Unfortunately, motorE, connected in port M1 of motor shield, stopped working. Could someone explain for me why if statement is causing that trouble for M1 port? Motor shield uses digital pins 3,4,5,6,7,8,9,10,11,12 of arduino board.Here's the code:
#include <AFMotor.h>AF_DCMotor motorE(1);AF_DCMotor motorD(2);#include <SoftwareSerial.h>
const int sio = 2; // ColorPAL connected to pin 2const int unused = 255; // Non-existant pin # for SoftwareSerialconst int sioBaud = 4800;const int waitDelay = 200;
// Received RGB values from ColorPALint red;int grn;int blu;
// Set up two software serials on the same pin.SoftwareSerial serin(sio, unused);SoftwareSerial serout(unused, sio);
void setup() { Serial.begin(9600); reset(); // Send reset to ColorPal serout.begin(sioBaud); pinMode(sio, OUTPUT); serout.print("= (00 $ m) !"); // Loop print values, see ColorPAL documentation serout.end(); // Discontinue serial port for transmitting
serin.begin(sioBaud); // Set up serial port for receiving pinMode(sio, INPUT);}
void loop() { readData(); motorD.run(FORWARD); motorE.run(FORWARD); motorD.setSpeed(180); motorE.setSpeed(180); if((red>130)&&(red<150)&&(grn>110)&&(grn<130)&&(blu>150)&&(blu<170)){ motorD.run(FORWARD); motorE.run(FORWARD); motorD.setSpeed(180); motorE.setSpeed(180); delay(2000);}
// Reset ColorPAL; see ColorPAL documentation for sequencevoid reset() { delay(200); pinMode(sio, OUTPUT); digitalWrite(sio, LOW); pinMode(sio, INPUT); while (digitalRead(sio) != HIGH); pinMode(sio, OUTPUT); digitalWrite(sio, LOW); delay(80); pinMode(sio, INPUT); delay(waitDelay);}
void readData() { char buffer[32]; if (serin.available() > 0) { // Wait for a $ character, then read three 3 digit hex numbers buffer[0] = serin.read(); if (buffer[0] == '$') { for(int i = 0; i < 9; i++) { while (serin.available() == 0); // Wait for next input character buffer = serin.read(); if (buffer == '$') // Return early if $ character encountered return; } parseAndPrint(buffer); delay(10); } }}
// Parse the hex data into integersvoid parseAndPrint(char * data) { sscanf (data, "%3x%3x%3x", &red, &grn, &blu); char buffer[32]; sprintf(buffer, "R%4.4d G%4.4d B%4.4d", red, grn, blu); Serial.println(buffer);}
If it is an internal timer conflict, you could try a different software serial library in the hopes of locating one that plays along. Or you could try using the hardware serial in pins 0 and 1. You'll probably need to temporarily disconnect the ColorPAL while uploading your sketches, and you will not be able to use the Serial Monitor for debugging feedback. Another option is to use the Arduino Mega, which has more timers and hardware serial ports.
