Defective soldering on Quickstart board
Jeff Haas
in Propeller 1
I was trying to learn Spin and was trying something on my Quickstart board, and found that some of the pins just weren't responding. This was making me go around in circles (Do I understand the pin numbering right? Do I not understand how to blink an LED in Spin???) until I took a very close look at the solder joints that hold the header down. Many of them in the center of the header have little or no solder on them. It seems the center of the header got no solder applied at all. A quick test with the multitester showed that that was the problem.
Question: Has anyone else seen this?
I'm going to try to fix this myself, I hope I can get it right!
Any chance you could post "before" and "after" photo of the solder joints, so we can see what you found, and how you could fix it ?
Or at least a "before" image.... some of the soldering gurus here might be able to offer some tips!
me. My cell phone camera is good enough to get this. The ones on the
right are obviously what I soldered, and you can see the ones in the
middle without any solder on the pads.
It's late and I'm going to bed!
The guys are right to suggest you contact Parallax.
They will get you going again... Here's the contact details:
support@parallax.com or 888-997-8267
All the best!
https://www.parallax.com/product/721-00017It makes pin ID wonderfull!
Jim
(Tech might want the other back to check where in the manufacturing process it went wrong)
Jeff
The new board arrived today (I'm in California) and I discovered there are some features that have been upgraded from version A - the pins can be accessed from the bottom of the board as well as the top, and they are also labelled on the bottom!
Thanks again to everyone.
