Mini USB VGA adapter pinout — Parallax Forums
tonyp12tonyp12 Posts: 1,951
edited 2015-02-12 21:07 in Propeller 1
A VGA connector is pretty big and clunky.
In the automotive DVD entertainment they went with mini-usb and the cables are still easy to get hold of.
http://www.aliexpress.com/item/Good-quality-Free-Shipping-VGA-to-VGA-cable-mini-5P-line-moves-DV-cable-Mini-USB/32263187427.html
Order max 6 as to get free shipping, my order toke about 2weeks to arrive.
I tested the pins and found out this pin out. (note Shield is Ground, put vias on shield pads to help holding it down )
Connector in the picture is the: UX60SC-MB-5ST and is available in Diptrace
http://www.mouser.com/Connectors/USB-Connectors/_/N-88hmfZscv7?Keyword=UX60SC-MB-5ST&FS=True&Ns=Pricing|0
Step file: http://www.hirose-connectors.com/connectors/InproductionSearch.aspx?T2=UX60SC-MB-5ST
494 x 526 - 41K
  • jmgjmg Posts: 15,200
    edited 2015-02-12 11:59
    tonyp12 wrote: »
    I've seen these - Is this pinout reasonably standard ?
    tonyp12 wrote: »
    ..... (note Shield is Ground, put vias on shield pads to help holding it down )
    Personally, I avoid the pure SMD USB connectors like the plague, and use the ones with 4 Pin-thrus for maximum strength - and usually expand the land and paste areas as well.
    I've even seen some Eval boards use a totally pin-thru connector. (9 holes)
    Micro USB appeals as a now standard for chargers, but as more emerge I'm not that impressed with their reliability.
    They may have made a bad choice there. Too small and flimsy ?
  • tonyp12tonyp12 Posts: 1,951
    edited 2015-02-12 12:11
    I think this is the standard, I googled it and there is no picture of the pinpout anywhere so that is why I ordered a few.
    Diptrace and mouser have many UX60 versions, some with posts and also shield through pins
    With micro-usb I always go with top mount version as when connector is placed (inverted) that part of shield housing is broader and should give more support.
    edited 2015-02-12 16:39
    Shield as ground is a bit dodgy. For a shield to be effective as a shield, it should be connected at one end only. It might have been better to dedicate a pin to ground and combine the two syncs, or put one of the syncs on green. Of course, not all VGA monitors could deal with something like that.
    Still, though, I like the concept of getting away from that huge DB9.
    edited 2015-02-12 17:05
    Clever idea. I know a microscope ringlight manufacturer that uses HDMI connectors and cables for the connections between the light and controller. Robust, lots of lines in a small diameter cable, and cheap.
    If you are going for small and space saving, I just did a prototype using the Molex 47642-001 Mid-Mount Micro USB connector. Your PCB needs to have a cutout for it to fit properly, but the finished board looks pretty sweet and the connector installation is much stronger than a full SMT version. It was placed using pin-in-paste methods, meaning that solderpaste was also printed over the 4 mounting holes. After reflow, the TH tabs were soldered with about 70% fill. Can't show a pic of the prototype (under an NDA), but here is a screenshot of the board layout and connector.
    http://www.molex.com/molex/products/datasheet.jsp?part=active/0476420001_IO_CONNECTORS.xml&channel=Products
    Digikey PN WM1398
    http://www.digikey.com/product-detail/en/0476420001/WM1398CT-ND/2350884
    220 x 150 - 7K
    edited 2015-02-12 17:40
    There are HDMI to D-SUB HD15 cables (or its is the other way around) they of course don't convert but I think they are used to make your PC video card secondary hdmi port in to a vga port if the video card support that.
    http://www.aliexpress.com/item/Hight-quality-6FT-1-8M-HDMI-To-VGA-Cable-male-to-male-Video-Adapter-For-HDTV/32238681634.html
    I guess I have to order a few to get pinout on those, should be plenty of gnd wires for it to use.
    But when your products video-out port is a female hdmi connector , they are gone connect it to a TV's hdmi port. a lot of confusion
    And it's bigger than mini-usb nearly back to vga connector size we tried to avoid in the first place.
  • TubularTubular Posts: 4,774
    edited 2015-02-12 19:56
    Interesting. If you accidently plug a standard usb mini cable in, where does the +5v end up? On the H or Red pin?
    If its the H-pin perhaps a relatively large (compared to 240 ohm) series resistor might protect the prop. Or a clamping diode
    edited 2015-02-12 20:23
    I've always hated those bulky VGA connectors when all you need is 5 pins and an optional shield. So I've used pin headers and it's pretty simple with those "Dupont headers" from ebay, either as a single 5-way or an dual 4-way. So the other end of the cable may terminate into a female or male VGA as required. So the shield being the ground is not really a problem for these short lengths.
    yes pin1 (the round dot on pcb), I would use 470ohm and a 3.6v zener between the prop-pin and resistor for safety.
