Memory Interface and IO Peripherals in 2015
jmg
As time marches forward, the level of integration on small controllers continues to climb,
The new NUC505 has some topical examples :
This has
Core
- ARM® Cortex®-M4F with DSP and FPU
- Max frequency of 100 MHz
- Temperature range: -40℃ ~ 105℃
Memory
- 128 KB of embedded SRAM
- 2 MB of SPI Flash
Connectivity
- USB 2.0 HS Device
- Up to two USB 2.0 FS Host
- Up to three UARTs
- Up to three SPIs
- Up to two I²Cs (Up to 1 MHz)
- SD Host
Security for code protect
- 128-bit key for code protection against illegal pirating
- Supports multi-entry for 15 times
RTC
- Supports external power pin VBAT
- 32 bytes spare registers
I²S
- Supports Master or Slave mode operation
- Internal PLL for frequency adjustment
- Supports PCM mode A, PCM mode B, I²S and MSB justified data format
- Supports DMA mode
12-bit ADC
- Up to eight channels
- Up to 1MSPS conversion with ADC_CH1, and up to 200 kSPS with others (except ADC_CH0)
Audio CODEC
- Embedded Stereo 24-bit Sigma-Delta CODEC output
- ADC-THDN: -80 dB, Dynamic Range SNR: 90 dB (A-Weighted)
- Headphone Output-THDN:-60dB, Dynamic Range SNR: 93 dB (A-Weighted)
- Sample Rate: 8 kHz to 96 kHz
Packages
- LQFP48, LQFP64, QFN88
http://www.nuvoton.com/hq/products/microcontrollers/arm-cortex-m4-mcus/nuc505-series/Technical-Reference-Manual/?__locale=en&resourcePage=Y
The most interesting and P2 relevant 'peripherals' are the 2MB SPI with DMA support & 200Mbps is shown on SD Host link - as well as the 24b ADC and multiple USB FS/HS links .
My guess is Nuvoton use a Winbond SPI as stacked die, & they mention HW in-line cypher encryption for R/W of external SPI.
Packages as small as TQFP48
With the DMA and speeds mentioned, that delivers an impressive level of Serial Memory support, and having 2MB included inside the package, is a bonus.
I think P2 needs to be USB-capable, and have SPI HW that can do QuadSPI (DDR?)
This has
Core
Memory
- 2 MB of SPI Flash
Connectivity
- USB 2.0 HS Device
- Up to three UARTs
- Up to three SPIs
- SD Host
RTC
I²S
- Supports DMA mode
12-bit ADC
Audio CODEC
Packages
* Remove all but 1 of the cogs (maybe keep a second one that is customized to do nothing but floating-point operations).
* Significantly reduce the number of registers in the cog and force the cog to run in HUBEXEC mode only (which will further allow a reduction in cog memory size).
* Remove the per-pin smart i/o, and instead dedicate specific pins to specific functions.
This should free up enough room to make a lot more of those other features available.
The good news is nothing nearly as radical as your suggestions are needed.
It is a simple matter of learning from others, and in the P2 context here, the focus is on the SPI memory support.
Nuvoton have HW 200Mbps Quad data path support, and if I understood the presentation they also have
* hw DMA
* Cypher support, in line and real time
* Memory mapping, so eXecute In Place is possible.
All up, it looks a nicely balanced design, for a chip that is RAM based and boots from SPI.
The expectation is the P2 will have SPI HW support (hopefully QuadSPI), and Memory mapping would allow HUBEXEC to also work as 'SPIEXEC', into megabytes of code space.
Load it to HubRAM and run from there thank you very much. If that means something like overlays then so be it.
Streaming data transfers should be about as far as any hardware needs to go. This would apply to SDRAM also. Leave the native execution to Cog/Hub accesses only. Be glad we're getting native HubExec.
I think that is the intended mode for the NUC505 for critical Code flows, but there are cases where data may reside in SPI Flash, where efficient (ie HW supported) addressing and burst streaming will increase throughput, and make the code to access that data simpler.
Yes, SPI will always be slower than on-chip parallel access, but the point is to ensure to improve the bottle necks, rather than ignore them because something else is faster.
SPI is much larger, and cheaper, than on chip RAM, so it has an important place in the design toolbox on a part like the P2.
Sure they are, but i2c is WAY slower than 200Mbps.
Using a COG to just wiggle pins, is a terrible waste of silicon, and will always be slower, and less power efficient, than HW support.
QuadSPI is not complex Verilog, and is very easy to test.
The reality is, devices like the NUC505 set users expectations.
And totalIy worthless discusion about hardware that is not possible to buy.
Remember Spansion hyperbus? Announced in March 2014, no distributor has them yet. (even ISSI talked about making hyperRAM)
Remember FTDI FT900 series? Announced in Feb 2014, no distributor has them yet. (Also I wonder how much will we wait for the announced FTDI FT600 that allows USB3.0)
Remember Lattice MachXO3 announced with gigabit ethernet and many other things? After more than 6 months they delivered something really behind their own marketing expectations.
Please, talk about something that can be actually bought (on digikey, mouser, anywhere). This is not the first time that someone announce a revolutionary IC that never see the light.
You cannot buy a P2 either
QuadSPI is not a revolutionary IC that never see the light - it has been available for some time.
MCU with QuadSPI interface support are also available now.
( There are also Show dates, BSP downloads, TRM, & NuTiny-SDK-NUC505 showing (with what looks a kosher 2014 week 40 date code?) , all up making a NUC505 much closer than P2.)
Thus NUC505 is more incremental than revolutionary, in that they include a 2MB SPI in the package, and add well-thought-out hardware support, to make what is a cheap, but modest bandwidth, pathway easier to use, and with little waste.
The one argument that does make some sense is on the basis of power efficiency. A specific hardware solution is usually more power efficient. But it still needs to be a correct solution. Where's the full spec for Quad-SPI?
The Data sheets spec the SPI details, and give the wide price / size options, I would target at least 2 points
Examples could be (- these are real devices, on the shelf, and easy to test on a FPGA board.)
sub 50c/1k : 24b Address, Low cost parts 2MByte
http://www.winbond.com/NR/rdonlyres/0143840F-8550-480A-9C1C-9261DE1DFCD7/0/W25Q16DV.pdf
~ $2/1k Double Transfer Rate added, 32b Address, 32M Byte
http://www.micron.com/~/media/Documents/Products/Data%20Sheet/NOR%20Flash/Serial%20NOR/N25Q/n25q_256mb_3v_65nm.pdf
The DTR feature option allows even more system power savings, and lower RFI..
You don't need to buy it. It is FREE. You just only need to buy the DE0-NANO EC4CE22 and throw the bitstream to it. The P2 is real. Trust me.
I was indeed joking. The "changed" version I suggested was basically the NUC505 itself. The point is: let the P2 be what it's going to be and stop trying to make it be like something else. I know the addition of QSPI would be useful in some circumstances, but so would a heap of other technologies. Frankly, I am still amazed at what people were able to pull off with the P1, most of which was probably not even thought possible when the P1 was first released. I suspect the same will be true for P2.
Then we actually agree, and given the P2 will connect to some SPI memory in every application, and QSPI is mature technology, and cheap, users are simply going to expect that is supported.
It's not really 'technology', more a matter of balanced system design.
A lobotomised P2 that fails to hit critical mass, helps no one, and history has many examples of MCUs that failed with one factor being they failed balanced system design.
Correct, qSPI is not a complex addition from SPI at all, it just needs a nibble pathway supported to the pins & a config boolean.
Chip has indicated before this is likely.
The qSPI.DTR option sends data on both edges of the SPI_CLK, so that adds a MUX and Byte pathway, & another config boolean, still elementary levels of Logic.
I wish there will be no new image, just the P2 IC.
Hyperbus would be nice, but unless there is real silicon to test, that is hard to envision.
However, there is a lot of QuadSPI (DTR too) out there that is easy to test with.
A direct jump to P2 is very unlikely, as that would make the Parallax FPGA board a waste of time, and the idea behind that, is to allow extensive field testing of code revisions.
Ken wants to avoid (or make the risk as low as possible) of a 2nd tapeout, for obvious reasons.
If the idea of code revisions really does scare you, then perhaps take a break from the P2 development until the revisions stop ?
It does beg the question as to why you might want so much community discussion when you already think it's included?
NUC505YO13Y Nuvoton Technology Corp M4 WITH FLASH BASED , 88PIN Stock: 1344 $3.20 (@ 1344)
Spansion's 64Mb HyperRAM will be sampling in 2Q15. It will be available in both 3V and 1.8V versions packaged in the market compatible 5x5 array BGA.
The Spansion HyperFlash memory family will offer 3V and 1.8V power-supply versions and initially include three densities: 128Mb, 256Mb and 512Mb, with 512Mb samples available.
FTDI have the EVE80x parts, but they were too small and that left an opening for P2.
Now this news...
http://www.ftdichip.com/Products/ICs/FT81X.html
Maximum screen resolution increased from 512x512 pixels to 800x600 pixels
Bitmap size increased from 18-bit to 24-bit (FT812 and FT813)
Extra large ROM fonts added (There are a total of 19 ROM fonts)
Orientation switching support added with REG ROTATE and CMD SETROTATE
Main memory increased from 256kBytes to 1Mbyte
Master clock frequency improvement - REG PCLK can now be 1
Smooth back-motion JPG encoded AVI video playback
Multiple 16/32 bit colour palettes supported with transparency
L2 format supported for efficient DXT1-style bitmaps
CMD MEDIAFIFO specifies an area of main memory to use as a FIFO for JPG, AVI and PNG loading
Multiple numeric formats supported including binary, octal, decimal and hex
Simplified font loading with CMD SETFONT2
MCU transfer with QSPI interface option
Performance Improvements
500-1000 times faster JPG loading
Pixel clock drawing increased from 4 to 16 pixels per clock
Fetch cull primitives per clock boosted from 1 to 2
Quicker Firmware memory operations (e.g. copy, fill, CRC) due to tuned inner loops
CMD SNAPSHOT hundreds of times faster
Still, the P2 can always control one of these devices, but that QSPI looks more important by the day...
