colorPal 28380 — Parallax Forums
colorPal 28380
kazuya86kazuya86 Posts: 5
edited 2014-10-01 07:18 in Accessories
I use the colorpal_flicker.bs2 to display the colorpal flicker. But I close the basic stamp, the colorpal still flicker,and I can't use the colorpal_sense.bs2, I excute the TCS3200_ColorPal_match, it show unable to locate color sensor output on any serial port. Anyone can help me how to stop the colorPal flicker and i can excute the TCS_3200_ColorPal_match.exe
    edited 2014-09-30 09:56
    The flicker program stores itself in the ColorPAL's EEPROM so that it can be used without a BASIC Stamp attached. So you will need to get rid of it first. This is done by erasing it from the ColorPAL's EEPROM by replacing it with a blank program, thus:
    SEROUT sio, baud, ["= #00"]
  • kazuya86kazuya86 Posts: 5
    edited 2014-10-01 06:35
    it still flicker, i excute the program with the code
    PAUSE 1000
    SEROUT sio, baud, ["!"]
    DO:LOOP
    Can you give me more information to solve
    edited 2014-10-01 06:53
    See if this works:
    Make sure ColorPal in connected to PIN 15
    '   {$STAMP BS2}
    '   {$PBASIC 2.5}
    ' -----[ Program Description ]---------------------------------------------
    ' -----[ I/O Definitions ]-------------------------------------------------
    sio     PIN 15           ' Serial I/O com pin for ColorPAL.
    ' -----[ Constants ]-------------------------------------------------------
    ' Baudrate definitions. Serial I/O must be open-drain. The ColorPAL includes
    ' a pullup internally.
    #SELECT $STAMP
      #CASE BS2, BS2E, BS2PE
        baud    CON  119 + 32768
      #CASE BS2SX, BS2P
        baud    CON  327 + 32768
      #CASE BS2PX
        baud    CON  536 + 32768
    #ENDSELECT
    ' -----[ Variables ]-------------------------------------------------------
    ' -----[ Initialization ]--------------------------------------------------
    ' -----[ Program Code ]----------------------------------------------------
    SEROUT sio, baud, SEROUT sio, baud, ["= #00"]
    PAUSE 1000
    edited 2014-10-01 07:13
    Thank you for providing the requested information.
    I find the problem, I set the pause on Reset equal to 1000
    and the sensor stop to flicker.
    Good news!.
    And welcome to the forums.
