How would you short 3 wires of a BLDC motor together?
One of the properties of a brushless DC motor is that if you tie all three leads together the motor does not want to spin, so you have a built in brake. I don't want to use relays, but am wanting to find out what other method I can use to tie the three leads together with a 3v3 control voltage off the prop. I am thinking about 2 n channel mosfets wired back to back off each wire to a bus. Any ideas on how you would do this? 24VDC, max is 3 amps pulled by the motor driver. I will add a method to detect that the shorts have been removed before allowing the motor driver to spin the motor.
Marcus
Relays might be a good way to go. But I would look into snubbing circuitry on the switching side to provide longevity to the relay switching points. Everyone suggests a fly-back diode on the coils to protect the longevity of the processor, but circuitry on the switching side is often ignored.
Most interesting is that you might simply drive one coil and has a triple pole, single throw switch set up on the other side. (you might have to settle for a triple pole double throw and not use half.)
http://www.globalspec.com/ds/317/areaspec/spec_pole_triple
Why no relays? Phil's example seems to be a nice and small example.
Marcus
http://www.ti.com/lit/ds/symlink/drv10983.pdf
9.4.3.4 Motor Brake
The motor brake function can be used to stop the spinning motor before attempting to start the motor. The brake
is applied by turning on all three of the low-side driver FETs.
If the motor is spinning at a speed that is greater than the braking threshold (configured by BrkDoneThr[2:0]),
then dynamic braking acts to stop the spinning
http://ww1.microchip.com/downloads/en/DeviceDoc/Regenerative%20Braking%20of%20BLDC%20Motors.pdf
Jim
This is a function for the motor-driver to perform really, it already has all the switches and it knows when its
safe to do it.
Well..yes. this is how I drive every day.
http://en.wikipedia.org/wiki/Left-foot_braking.
After not having a clutch vehicle for a while, I had to do some workouts with my left leg to gain some strength.
Jim
touche
