Extra possibilitys on DE2-115 — Parallax Forums
SapiehaSapieha Posts: 2,964
edited 2013-04-19 16:40 in Propeller 2
Hi Chip
One Question.
If I send You VHD else Verilog code to that.
Is it possible You can incorporate that to Config file for DE2-115 to give some extra debuging possibilitys
3x HEX LED's connected in parallel with LED0..11 on port B
'' --- Port B ---------------------------------
  LED0  = 32                    '' DE2-115        HEX 00
  LED1  = 33                    '' DE2-115        HEX 01
  LED2  = 34                    '' DE2-115        HEX 02
  LED3  = 35                    '' DE2-115        HEX 03
  LED4  = 36                    '' DE2-115        HEX 10
  LED5  = 37                    '' DE2-115        HEX 11
  LED6  = 38                    '' DE2-115        HEX 12
  LED7  = 39                    '' DE2-115        HEX 13
  LED8  = 40                    '' DE2-115        HEX 20
  LED9  = 41                    '' DE2-115        HEX 21
  LED10 = 42                    '' DE2-115        HEX 22
  LED11 = 43                    '' DE2-115        HEX 23
  • cgraceycgracey Posts: 14,133
    edited 2013-04-19 16:25
    Possibly. I understand that you want to P32..P43 to drive some 7-segment LEDs on the DE2-115 that are labelled "HEX". Do you just want those connections made?
  • SapiehaSapieha Posts: 2,964
    Hi Chip.
    It is 3x7 segment HEX displays (3 from right to left) bottom on LCD that I'm are thinking on.
    Driving them parallel with LED0..11 that You have it now
    cgracey wrote: »
