Translating encoder ticks/PID feedback to pwm — Parallax Forums
rwgast_logicdesignrwgast_logicdesign Posts: 1,464
edited 2012-12-30 18:38 in Robotics
Im sorry if this question sounds rediculoud but ive been reading for hours and cant come up with a solution to scalind a pid algorithim to a how fast to pulse a pwm line. Basically I just want to keep a my motors at the same speed using PID and encoders along with a compass to compensate for any long term encoder error.
So basically the idea is if one encoder is at 400 ticks and the other is at 300 slow one down by 50 ticks and speed one up by 50. But how do you scale encoder ticks to a 1 through 255 pwm setting, or and duty cycle for that matter.
    edited 2012-12-29 08:35
    For PWM you use a fixed frequency, but vary the duty cycle. Rather than jump right into PID, you might want to try a proportional scheme (the P in PID) . The idea is to consider the error each wheel has from the target state and alter the control signal proportional to that error. So if the goal is 350 and you are at 300 then your error is 50. You would take the current control signal and add a correction factor which is the error scaled by the P constant. The P constant can be hardwired into the code, but I've seen people use trimpots and an ADC to allow dynamic tuning while the robot is running. Note that the sign from the initial subtraction will result in a decrease of the control signal if you are above the target.
    Once you get that working the integral and derivative can be added on later, but a proportional scheme gives you most of the bang for the buck. I'm about to learn a whole lot more about PID because I need it for some projects in the planning stage. It's really useful for fast line following where the line is allowed to have sharp bends for example.
  • ZootZoot Posts: 2,227
    edited 2012-12-29 08:50
    The PID calculations can be considered separately from the nugget (I think) of your question -- scaling the calculated output to match the PWM range for the motors.
    There are many approaches, so consider this just my approach for velocity control (for odometry I always work in encoder "ticks"):
    - first I convert encoder "ticks" on each sample to a theoretical PWM value (i.e., I scale the ticks read to a motor speed value). In my case, I usually use 128 as stop, 255 as full forward, 0 as full reverse. So if I sample encoder ticks every 20ms, I convert the speed (count) and direction to a 0-128-255 value. I usually use the equivalent of */ or ** (mid-multiply or high-multiply) and I take into account rounding errors to get the best measured speed.
    - that "speed" can now be comapred directly to my "desired" user speed. So if my converted speed from reading encoder ticks is 138 (a slow forward) and my target speed is 140, I know I have an error of 2. That error can be fed into your P, I and D terms. Given that you are working in "speeds", the result can be put right back into your PWM values.
    - for practical purposes, I've found that using an impulse factor gave me much better results than straight PID. There are a number of after-market motion controllers (motor drivers with built in encoder feedback and PID algorithms built-in) that use this approach. Essentially, I take the target user speed and scale that to about 80% as my "base" output figure. The rest of the final PWM value is derived from PID correction. I also always account for integral wind-up (a max integral saved error) for the I term and I usually clear the saved I term to 0 upon a direction change.
    - for figuring the scaling factor for ticks to speed, I usually run the motors at 80% duty and measure the ticks output. That's "full speed". The other 20% gives me overhead to run the motors at higher duties to hit target speeds comfortably (especially as batteries run down).
    edited 2012-12-29 17:53
    Thank both of you guys so much.
    Zoot gave me a better answer than i could have hoped for, there is info on PID all over but nothing about a reasonable way to scale it to a meanigfull dutty cycle. Id also like to take compass reading every so often and and use a PID loop to make the bot follow a straight heading, kind of keeping the encoders in check.
    I was originally going to make my Arduino based motor controller handel the PID for the encoders, but im not sure it will handel 2000 interupts per second to well let alone 4500 if i upgrade to 4 wheel drive. Im staring to think i might let the propeller handel the encoders, as thats where the compass will be attached to also.
    edited 2012-12-29 18:01
    It's way easier than that. You can adjust the overall PWM rate to attain the correct average speed. But for synchronizing two wheels, just omit pulses from the wheel that gets ahead of the other one. At least that's the way it's done in the S2, and it has good tracking accuracy without using a PID loop.
    edited 2012-12-30 04:16
    I've used this with CR servos since they coast when you don't pulse them, so keeping the pulse counts synchronized is easy. But with a PWM/H bridge pair I figured it would require over correcting the faster motor until the other side catches up, then speeding it up again to match. This seemed pretty complicated which is one reason why I abandoned my encoder hacked S1
    Do you put the side that is ahead into coast mode on the S2?
    The biggest reason I abandoned my encoder hacked S1 was it lacked dynamic breaking which CR servos have. Without that accurate odometry is really hard because you tend to coast past where you want to go. Erco, hacked the S1 farther to add this feature.
  • ercoerco Posts: 20,254
    edited 2012-12-30 08:35
    Abandoned???
    You don't fail until you give up!
    Abandoned???
    Perhaps I should say I indefinitely postponed work on it to pursue more fruitful avenues of robotic self expression?
