Failed op amp in my HP 3311A Function Generator
I left my 3311A on last night and found that it wasn't working so well this morning. Looks like U5, the "tuning amplifier", isn't working as it should. The parts manual has it as HP part # 1826-0066 made by Fairchild with their part # as U587777312. Can't find it on the interwebs.
It's a TO-99 8 pin can style op amp. Does it looks familiar to anyone?
I'm gonna guess it's of the LM101/201/301 family from National:
http://www.utm.edu/staff/leeb/LM301.pdf
Studying the original circuit of your instrument, the age of its project, the external capacitor for frequency compensation (if possible with a magnifying glass or pencil microscope, check if its value is 47pF or .47pf as shown in the schematics) and the presence of a symmetry control (offset null) after the current source driver I strongly believe that you can use a LM748QML<=>LM748H/883 from Texas Instruments<=>National Semiconductor. Unfortunately I've found them only at Arrow at >US$ 17 each. Hope you can find a better/cheaper alternative;)
Yanomani
Looking at the circuit, you can probably substitute just about any op-amp there. I don't really see anything special with that one.
LM301 is probably a decent bet. If you can wire an 8-pin-DIP into the board, you'll save a lot of money; 8-DIP LM301 is $0.71 at DigiKey, while the metal can is $8.35.
http://www.ebay.com/itm/120922013514 Possibly dubious.
An LM312 may functionally work, but the pinout is different.
Today, I've got a Rigol DG1022 function generator coming as an early xmas present. I'll fix the HP and have it for back-up.
Thanks for the quick replies.... it's nice to see analog experts in this digital forum!
Thanks again,
Kevin
Thank you for the follow up. It's always nice to know "the rest of the story".
