Transistor switch recommendation
I need a trsnsistor switch to use between my BS2 output and a 12 volt solenoid valve drawing 1/2 amp. I would appreciate a PNP transistor switch recommendation.
Richard
Richard
is there some reason you need to switch the high side ?
a LOGIC MOSFET ,] 1 K pull down , diode accross the coil . volla!
Peter..
This P-Chanel MOSFET, IRF9Z34, is good for about 3 Amps with no heat sink.
Duane J
I don't think this series of MOSFETs will work with the 3.3V drive from a Prop.
These are old school types with 20V gates.
OK, I haven't done my own gate characterization of these but I don't think it will even start to conduct at 3.3V.
Like Phil said, the IRF3708 is a much better choice for a Low Side Relay Driver.
Follow the link and you can see my gate measurements.
Duane J
He's using a BASIC Stamp, not a Prop; but even with a 5V drive, I think the IRF3708 is the better choice.
I was spouting a Old fet as the OP might not want to wait for a fet .. shack has the 520 in the bin .
http://www.youtube.com/watch?v=gjrSVzxpBAo
2-relay 5V, $3.69: http://www.ebay.com/itm/5V-2-4-8-Channel-Electronic-Relay-Module-for-Arduino-8051-ARM-PIC-AVR-DSP-TTL-/160826465383?pt=LH_DefaultDomain_0&var=&hash=item2572011c67
4-relay 5V $5.69 http://www.ebay.com/itm/4-Channel-5V-Relay-Shield-Module-for-Arduino-ARM-PIC-AVR-DSP-aii-/180866396859?pt=LH_DefaultDomain_0&hash=item2a1c7a32bb
4-relay 12V $6.90 http://www.ebay.com/itm/4-Channel-12V-Relay-Module-For-Arduino-PIC-ARM-AVR-DSP-/250887128971?pt=LH_DefaultDomain_0&hash=item3a6a09c78b
Richard
You could always add an external transistor switch to each line for use with those relay modules if you want to safely drive 8 relays at once.
The ULN 2003/2803 is a 7-channel (DOH!) solution for switching discrete relays and interfaces directly to a Stamp: http://www.parallax.com/dl/docs/cols/nv/vol1/col/nv6.pdf
Stocked at Mouser (and probably Digi-Key also):
http://www.mouser.com/ProductDetail/Texas-Instruments/TPIC6595N/?qs=5nGYs9Do7G03SZwCnZXhhZVnGQDwLPOiD1U7MUGeamM%3d
Richard
