Creating a composite sync
Invent-O-Doc
So, I've been hooking up all my old computers again - got the atari 800 running and having lots of fun playing star raiders, archon and jumpman.
My atari 1040ST outputs RGB and has separate HSYNC and VSYNC. (it still uses NTSC timings). I found out my dad threw out my monitors, so all I have are some nice Sony 1271 studio monitors. They take either composite or RGB with CSYNC. (A commodore amiga is going to be on the second monitor)
My question is this - how do I make a composite sync? Can I get away with just tying the HSYNC and VSYNC lines together?
Lo and behold, the maintenance manual for the sony shows a 25 pin computer input (for a sony computer) - It has separate HSYNC and VSYNC there - I hooked everything up and - well, I can't lock vertical hold for some reason. Frustrating. If this bombs, I will end up making a sync combiner, but a DB-25 cable would be easier...
Thanks for the advice.
A good source of info on Atari computers is the forums at AtariAge http://www.atariage.com/forums/forum/20-atari-sttt-computers/
Forrest
I'm thinking of hooking up the vsync to an 74LS04 inverter to see if that will work, if it doesn't, then I'll make a cable to hook up to independent RGB and CSYNC on the back. I've read that the diode/resistor combo works without having to make a logic-based combiner. (I have a 74LS86, but it requires a 5V source). I'm fearful that 'negative polarity' means negative voltage and not inverted logic states (and hence the 74LS04 wont work)
Thanks again.
