Tips for wiring prop to ham radio for sending morse code
Deskguy
I have a ham radio that I want to connect to my prop for sending out morse code, through the key jack in the back of the radio.
The attached image is from the radio manual. I have a stereo plug and want to do the wiring like the diagram on the right. The radio has a built-in electronic keyer (it will make the correct length of dot and dash based on the radio settings).
BTW, the radio model is Yaesu FT-817.
Any suggestions?
Has anyone tried this and can point out any 'gotchas' that I should avoid?
Thanks!
David
Any suggestions?
Thanks!
David
Alternately, I would try using one or two prop outputs with 10K series resistors (because that is easy). Just use the prop as an open collector output(s) - that is, make the outa=0 and switch the dira=1 to output "0"=GND and dira=0 to output "open". I would suspect there would be some form of micro/gate in the radio with some protection anyway. If it works, then drop down to some lower value resistors like 4K7 or 2K7.
As Phil suggested, the diagram on the left would be easiest for the prop to control. You would require more complex code for the diagram on the right because effectively you would have to calculate all the timing in the prop anyway. You can still use a stereo connector, just wire the key to the dot (tip) and ground to the dash and common.
Thanks very much for the tips - definitely a bit more involved than I had first expected - glad I asked.
Appreciate the help.
David
Appreciate the tips!
David
