USB Keyboard with PS2 adapter....
Will a USB keyboard/Mouse work on the propeller with a PS2-to-USB adapter?
http://WhatsAvailable.org Software and Gadgets for Windows 7.
I am going to try and test it, the keyboard is roughly 2 years old so I am not to concerned if anything breaks on it, I just dont want to damage the prop just yet.
The mouse I dont like so I am hoping to fry it, it is one of the laser mice that dont have a ball. It just keeps jumping all over the place as I use my PC, so if it dont break I will place it behind, or infront, of my cars tire and give it some gas
I doubt that there's any "driver-magic" going on with your PC to somehow skip interpreting the signals from the PS/2 connector on the motherboard as anything other than PS/2 signals. That would be deceiving to the consumer, as it would suggest the presence of a PS/2 interface and the ability to use old-style PS/2-only devices (i.e., not USB), when, in fact, if such were the case, it couldn't actually use PS/2-only devices. It's worth speculating about, of course, but seems highly unlikely. I don't know about modern motherboards, but I believe that older ones employed a separate microcontroller to interpret the PS/2 mouse/keyboard signals. Perhaps things have changed a bit (such as incorporating such into a bridge chip or whatever), but it still seems likely that there is a hardware interface of some sort configured for PS/2 signals between the system CPU and the physical PS/2 connector on the motherboard. Of course, one way to verify that would be to plug an old-style PS/2-only keyboard or mouse into the connector on the motherboard and see if it works. Even if some kind of software-only solution were being used to interpret the PS/2 signals for use by the PC system, it wouldn't change the fact that the original signals were PS/2 signals. But you might not have an old-style PS/2-only device handy to try that. Nevertheless, I think you're quite safe in proceding with connecting to the Propeller based on the checking/thinking you've already done. Disclaimer/Full Disclosure: my knowledge about the P2/2 standard, motherboards and electronics in general is pretty limited; just trying to help. --Jim
Post Edited (JRetSapDoog) : 7/14/2010 8:15:11 PM GMT
I have run across a keyboard that didn't work on the prop even though it worked as a PS2 with a PC (it was a USB/PS2 keyboard). I didn't track down what the problem was, I suspect it was because the prop was 3.3V signals and the PC was 5V but I just used a different keyboard and it was the only one out of a few I have tried that didn't work.
I don't believe you can do anything to kill either the prop or keyboard or mouse by trying the adapter. They are just wires and the prop (provided you are using the resistor circuit) and the series resistors will protect the devices.
· Emulators: CPUs Z80 etc; Micros Altair etc;· Terminals·VT100 etc; (Index) ZiCog (Z80) , MoCog (6809)·
· Prop OS: SphinxOS·, PropDos , PropCmd··· Search the Propeller forums·(uses advanced Google search)
My cruising website is: ·www.bluemagic.biz·· MultiBlade Props: www.cluso.bluemagic.biz
