What are the standard clkfreq values above 80MHz?
KyeKye Posts: 2,200
edited July 2010 in Propeller 1 Vote Up0Vote Down
I'm working on a new VGA object and I figured out pretty much that you need to have an exact frequency output to get all monitors to lock at 60Hz. That screen slowly fadding to white problem·that others have had comes actually from the fact that by trying to calculate the VGA frequency output with integer math·you do not get an exact result that is usable for the pixel clock.
So... I'm just going to use precomputed·values and then·use a different one for each clock frequency.
So far I have 80Mhz, 100Mhz, and 96Mhz as supported values. Are there any more popular clock frequencies that people use?
Honestly, I'd rather not hardcode this but... I need 64 bit math to get a proper result and I'm not really that good at breaking stuff up yet.
What I need to do is this....··((6,293,750 * 4,294,967,296) / clkfreq)
If I had 64 bit math the result would then come out to 337,893,130... The exact answer I need is 337,893,131 so I need to round up after the divide.
Thanks for your help,
Oh, and about the screen slowly fadding to white error. The reason this happens is because the pixel clock is not as high as it needs to be for the number of pixels you are pumping out to the screen. Because of this, each frame to the monitor is longer than it should be and the monitor will probably see like a 59Hz signal instad of 60Hz. This causes the monitor to basically get confused. So, you can fix the problem by either increasing the pixel clock frequency until it matches the number of pixels sent to the screen or you can reduce the number of pixels sent to the screen.
Nyamekye,
Post Edited (Kye) : 7/1/2010 6:22:16 PM GMT
Nyamekye,
  • 30 Comments sorted by Date Added Votes
    edited July 2010 Vote Up0Vote Down
    I especially like 96mhz since the xtals are so much cheaper than the 6.250 xtals.
    [The Bug Stops Here]
  • SapiehaSapieha Posts: 2,964
    Hi Kye.
    I run so many different Frequencies that drivers that are not reprogramming have not any use for me.
    Regards
    Nothing is impossible, there are only different degrees of difficulty.
    For every stupid question there is at least one intelligent answer.
    Don't guess - ask instead.
    If you don't ask you won't know.
    If your gonna construct something, make it·as simple as·possible yet as versatile as posible.
    Sapieha
    Regards
    Sapieha
    _____________________________________________________
    If your gonna construct something, make it as simple as possible yet as versatile/usable as possible.
  • heaterheater Posts: 3,370
    10.4857600 MHz is poplar around here[noparse]:)[/noparse]
    That's a 6.553600 MHz XTAL which I have a few of. The fastest I have pushed the TriBladeProp so far.
    For BST users use #defines to set the frequency at build time and issue a warning if none is defined. Put the formula clearly in the code.
  • KyeKye Posts: 2,200
    So.... suggestions on how to do 64 bit math? =) Then I could fix this problem.
    Nyamekye,
    Nyamekye,
  • jazzedjazzed Posts: 11,803
    Kye said...
    What I need to do is this.... ((6,293,750 * 4,294,967,296) / clkfreq)
    Are both numbers in the numerator constant?
    If so, the numerator is evenly divisible by 100,000.
    But that would be too easy ....
    Propeller Pages: Propeller JVM
    Yes both numbers in the numerator are constants. I just have to divide by a changing clkfreq. But I need the most exact result possible rounded up.
    Nyamekye,
    Nyamekye,
  • TimmooreTimmoore Posts: 1,022
    Phil put up some spin code umath.spin sometime - can't find the pointer at the moment - 64bit unsign math, multi/div/add. div is 64 bit /32 bit -> 32bit.
    http://obex.parallax.com/objects/415/
    Spending great effort to support anything other than reasonable frequencies is very nice of you.
    People can use any frequency they like I guess as long as they realize what they're doing, but frequencies with big round numbers are commonly available. How much do those other frequencies cost for production? Is there really a great return in using them (other than that's what happened to be laying on the hobby workbench)?
    Cheers,
    --Steve
    I just want my code to be as flexible as possible. I don't mind taking up extra space for that. I'm trying very hard to avoid magic numbers.
    Nyamekye,
    Nyamekye,
    Okay, this solves it.
        pinGroup := constant(25_175_000 / 4)
        frequencyState := 1
        repeat 32
          pinGroup <<= 1
          frequencyState <-= 1
          if(pinGroup => clkfreq)
            pinGroup -= clkfreq
            frequencyState += 1
    pinGroup is a variable I'm resusing and frequencyState is the output.
    Rather nasty however. I would have liked a one line solution.
    Nyamekye,
    Nyamekye,
  • Cluso99Cluso99 Posts: 13,132
    Kye, I use 104MHz (6MHz * 16) because 6.5MHz xtals are cheap and readily available at DigiKey. Also I intend going to 108MHz (13.5MHz * 8) in the future as these are also readily available. To use these, a good pcb layout is mandatory. Also, Bill and others are using his 6.25MHz * 16 (100MHz) xtals.
    I did some work on calculations for my latest 1pin TV driver which uses the compiler to do the hard work in calculations which saves space in the actual code. It no doubt has the same inaccuracies due to rounding as you have found, but it may be worth a look for you. I was not originally aware I could create these calculations using the compiler.
    · Emulators: CPUs Z80 etc; Micros Altair etc;· Terminals·VT100 etc; (Index) ZiCog (Z80) , MoCog (6809)·
    · Prop OS: SphinxOS·, PropDos , PropCmd··· Search the Propeller forums·(uses advanced Google search)
    My cruising website is: ·www.bluemagic.biz·· MultiBlade Props: www.cluso.bluemagic.biz
    My Prop boards: P8XBlade2, RamBlade, CpuBlade, TriBlade
    Prop OS (also see Sphinx, PropDos, PropCmd, Spinix)
    Website: www.clusos.com
    Prop Tools (Index) , Emulators (Index) , ZiCog (Z80)
  • Tracy AllenTracy Allen Posts: 6,143
    Kye, a double precision accumulator is not necessary. This is a ratio calculation of the form
    f = x * a/b where x here is 232.
    a=NCO frequency desired = 6_293_750 in your original example
    b=cpu CLKFREQ = 80_000_000 for example, but this is a variable too.
    PRI frqVal(a, b) : f      ' return f = a/b * 2^32, given a<b, a<2^30, b<2^30
      repeat 32                           ' 32 bits
         a <<= 1
         f <<= 1
         if a => b
            a -= b
            f++
    returns f = 337_893_130 in your example with a=6_293_750 and b=80_000_000. That f is what goes into the frqa register for the NCO. The multiplication by 232 happens automatically in the algorithm.
    Tracy Allen
    www.emesystems.com
  • mparkmpark Posts: 1,151
    Crazy how similar Kye's and Tracy's algorithms are! It would be interesting to know how each of you gentlemen arrived at your solutions. Care to elaborate?
    Here is the code derived from Chip's code that I used to calculate the frqa counter for NTSC and PAL TV.
    PRI Setforxtalfreq : f | Freq, PropFreq, shift
    '' Return frqa value for the current clkfreq
    '' Derived from CTR.SPIN by Chip Gracey
      Freq := ocolsfrq * ocols * 8                          'frequency required
      shift := 4 - >|((Freq - 1) / 1_000_000)               'determine shift
      PropFreq := CLKFREQ
      if shift > 0                                          'if shift, pre-shift Freq or PropFreq left
        Freq <<= shift                                      'to maintain significant bits while
      if shift < 0                                          'insuring proper result
        PropFreq <<= -shift
      repeat 32                                             'perform long division of Freq / PropFreq
        f <<= 1
        if Freq => PropFreq
          Freq -= PropFreq
          f++                                               'compute frqa value
        Freq <<= 1
    I just took code from the synth object in the propeller library. Then modified it to add 1 to the final answer.
    Nyamekye,
    Nyamekye,
    Oh, that's what "frequencyState := 1" and the "<-=" are for! Clever!
    Takes up no extra code space too.
    Nyamekye,
    Nyamekye,
  • RinksCustomsRinksCustoms Posts: 531
    I've had a DIP32 prop running off of a scavenged 7.00 MHz crystal x16·(112MHz) with no problems, but if i recall right, the various guts in the P8x32A silicon start malfunctioning around 128MHz, but as always, i could be (and probably am) wrong.
    Tracy Allen said...
      repeat 32                           ' 32 bits
         a <<= 1
         f <<= 1
         if a => b
            a -= b
            f++
    It took me a few minutes to understand what was going on here. I learned not to long ago in my AEES course how binary math is done, and how it is accomplished within hardware.. the repeat loop to multiply is beautiful, because binary multiply can be·done as a series of additions. Its funny the more things i learn in colledge, the more i see implimented in the code i read.
    Quicker answers in the #propeller chat channel on freenode.net. Don't know squat about IRC? Download Pigin! So easy a caveman could do it...
    http://folding.stanford.edu/ - Donating some CPU/GPU downtime just might lead to a cure for cancer! My team stats.
    Post Edited (RinksCustoms) : 7/7/2010 10:11:32 PM GMT
    Cali was beautiful, glad to be home in NJ!
  • micronewbmicronewb Posts: 20
    I haven't ran into problems at 200 Mhz (25 x 8) but just started using this setup a couple days ago. I haven't had any success higher than that though.
  • Phil Pilgrim (PhiPi)Phil Pilgrim (PhiPi) Posts: 21,497
    micronewb,
    I'm dubious of your "25x8" claim. You might be getting programs to run at that setting, but your clock speed won't be 200MHz. The reason is that the PLL's free-running frequency tops out before 256MHz (at 16x), which means 128MHz at 8x. Basically, the PLL can't lock onto your crystal, since its frequency is way too high, and is free-running instead. According to the specs, the crystal frequency should be between 4MHz and 8MHz, although reliable operation can be had at 10MHz.
    “Perfection is achieved not when there is nothing more to add, but when there is nothing left to take away. -Antoine de Saint-Exupery
    phil, I agree this seems strange and I wish i could send u an oscilliscope pic but mine tops out at 100 MHz. So what I am doing is blinking two LEDS from two separate cogs. One is using the standard waitcnt(clkfreq + cnt) to blink 1 sec, the other is waitcnt(200_000_000 + cnt) and they blink in sync. I could be missing something so please correct if this is not right.
    clkfreq is just a value put into a register by the compiler -- in your case 200_000_000. It is not an actual frequency measurement. So, yes, your LEDs will be in sync, but slower than 1Hz. Since you have a scope, try outputting a frequency of 1KHz and see what the actual frequency is.
    well played phil, but this brings up a question. with a 25 MHz crystal and X8 multiplier it runs right at 121 MHz, how is this working? if the PLL can't lock the frequency then it should be running at 25 MHz or am I totally messed up on that? Not much experience with PLL...obviously
    The PLL has its own VCO (voltage-controlled oscillator). This oscillator is divided by 16 and phase-locked to the crystal frequency. (So, you see, PLLx8 is really PLL/2.) But it can only oscillate so fast on its own. If it can't lock onto the crystal, it just runs at it's top, free-running speed which, in your case, is 242MHz.
    good explanation thanks! i guess i will surrender to around 128 MHz is as fast as it can go.
  • lonesocklonesock Posts: 882
    Phil Pilgrim (PhiPi) said...
    Out of curiosity, does this mean I could run the prop with the crystal pins as no-connects, specify a '_clkmode = xtal1 + pll8x', and end up with, in effect, a 'RCSUPERFAST'? Knowing, of course, that I no longer have any timing precision.
    Jonathan
    lonesock
    Piranha are people too.
    (geek humor escalation => "There are 100 types of people: those who understand binary, and those who understand bit masks")
    Free time status: see my avatar [8^)
    F32 - fast & concise floating point: OBEX, Thread
    Unrelated to the prop: KISSlicer
    'Dunno. Try it! Of course, since the "crystal" is oscillating at 0Hz, you may end up discovering the VCO's low-end frequency!
    So, if you use an external oscilator how fast could you go with cooling...
    Nyamekye,
    Nyamekye,
    Coley holds the record for uncooled speed. He topped out IIRC ~148MHz using an external oscillator and overvoltage. On a standard 3V3 Sapieha has had my TriBlade running at 120MHz with a 15MHz x8 for many months (if still running it is over a year). Chip said the PLL tops out at around 14.5MHz and it sort of confirms what I found with the RamBlade. IIRC I got 14.31818MHz x8 running. 13.5MHz x8 seems to run fine too. 7.3xxMHz x16 fails.
    From my tests I believe the DIP is more tolerant - don't ask me why as I haven't a clue.
    As for cooling, theoretically it should go faster, but the chip is not getting hot.
