0-10v lighting control
I'm looking to control some 0-10v lighting circuits. Is there any devices that I could connect and program with a basic stamp module that will allow me to control resistance of a circuit and therefore control a 0-10v output.
Cheers
Cheers
Use the Stamp's PWM output to charge the cap to a 0-5V value. The op amp will double that voltage to give you the required 0-10V range. Be sure to mount all of this stuff close to the lighting controller. The LM358 is not designed to drive a long cable. Also, with a voltage output circuit, resistive losses in a cable would limit the top end of your voltage range.
"puff"...... Smile, there went another one.
