no solder mask!
I feel pretty dumb. I ordered ExpressPCB miniboards without solder mask and did not realize how difficult it would be to solder through-hole components without creating solder bridges to the ground plane... When I made the decision to go without solder mask I·only considered that·I wouldn't have problems bridging the pins of DIP components. Please, does anyone have any tips? I don't mind trashing the current board.
Lots of propeller based products in stock at affordable prices.
Are you using a wave soldering machine or other automated machine to do the soldering? I can see where some surface mount parts may be a bit more difficult to solder without a solder mask but most through hole parts should still be easy to solder. Could you post a picture of the board so we can see the issue? As someone already mentioned solder wick is great for cleaning up solder bridges.
Robert
John R.
Click here to see my Nomad Build Log
Parallax Engineering
I used a 20 watt iron and 62/36/2 rosin-core solder.
John R.
those soldered pins look bad but they do not look unsalvageable. You might be able to simply reheat them one at a time and allow the solder to flow toward the pin. In cases like this, surface tension can be your friend. It might help a little to snip off some of the protruding legs of your component first so they do not act like thermal radiators that dissipate your soldering heat. But don't snip off too much of the leg: you want some of it to stick up so you can press your soldering iron up against it so it will conduct the heat down to the hole. Also, some of what you're looking at might be flux from your solder, which sometimes reflects light and looks metallic, and which can be scrubbed off with a clean toothbrush and pure ethyl alcohol, like the kind you get from Home Depot. If any solder whiskers remain after that, then try out solder wick, as several people have already suggested.
If you're having troubles, it might be because your soldering tip is too fat. Or, if you can't really see what you're doing, you might try a magnifier of some kind with good lighting.
To cut the pins short before or after soldering? I'm still pondering the merits of either, but I do have some old components that are >20 years and they get oxide on the outside, and cutting before soldering at least gives some bare metal to join to. So my current philosophy is to cut before soldering on older components. New boards + new components are a pleasure to solder - if I'm in a good rhythm I can do two joints per second.
If the join is visible on a photo but not to the naked eye - do you have a good lamp over the work area? I've found a 100W desk lamp right up close helps a lot - and I've gone for the compact flourescent globe as it does not get nearly as hot.
www.smarthome.viviti.com/propeller
