What are the requirements for OSC1? — Parallax Forums
Sens-a-DatSens-a-Dat Posts: 44
edited 2010-08-03 05:58 in General Discussion
I am considering the use of an external clock signal to be used for the SX48. I understand the signal is to be connected to OSC1.
What are the electrical requirements for this to work properly?
Thank you,
Gary
  • ZootZoot Posts: 2,227
    edited 2010-05-28 06:09
    TTL
  • dkemppaidkemppai Posts: 315
    edited 2010-07-29 20:19
    Sens-a-Dat said...
    Thank you,
    Gary
    5V Cmos or TTL. Nothing below that seems to work. You probably won't find it in the data sheet.
    (I know, I have a batch of boards with 3.3V osc's. And they won't clock the SX! Have to manually modify each board for a 5V osc)· [noparse]:([/noparse]
    -Dan
    "A saint-like quantity of patience is a help, if this is unavailable, a salty vocabulary works nearly as well." - A. S. Weaver
    edited 2010-07-31 17:03
    Does this mean that an Xtal with the SX powered at 3.3v will not clock as well?
    Ain't gadetry a wonderful thing?
    aka G. Herzog [noparse][[/noparse] 黃鶴 ] in Taiwan
  • PJMontyPJMonty Posts: 983
    Dan,
    I have a project that runs at 3.3 volts and has a 3.3 volt oscillator chip driving it and it all works just fine. Are you trying to use a 3.3 volt clock with a 5 volt SX project? The project in question is the 6 port RS-485 hub that I built. There's a two part article I wrote about it in Circuit Cellar a few months back. I use a pre-packaged clock chip and divide it by two using a 74LV74, which is basically the 74xx TTL parts designed to run on anything from 2 to 5.5 volts.
    PeterM
