Grossly expensive crimp tools
Not knowing how these crimp tools work, I would like to know if each crimp connector takes a specific crimper, or how it works. For example I am using this
search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=455-1133-1-ND
and need this ? search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=455-1134-ND for a mere $440.
www.rapidonline.com/Tools-Fasteners-Production-Equipment/Hand-Tools/Tacking-Crimping/Crimping-tool-for-PCB-connectors/30535
Leon
Amateur radio callsign: G1HSM
Since the terminal you cite is designed for 18-22 AWG wire, something like Leon suggested should work fine. I've even gotten good crimps on terminals like that with this cheap thing from RadioShack. It's when you get to the really tiny terminals that specialty crimpers are an absolute must. But, in those cases, I just buy pre-crimped wires from DigiKey.
This is probably too much information, but the pictures of the right vs. wrong crimps might come in handy: see attachment.
www.aeroelectric.com/Mfgr_Data/Connectors/Molex_Waldom/Hand_crimper_tooling_specification.pdf
WHAT COULD IT POSSIBLY DO TO BE WORTH $100+?!?!?!?!?
Computers are microcontrolled.
Robots are microcontrolled.
I am microcontrolled.
But you·can·call me micro.
Want to·experiment with the SX or just put together a cool project?
SX Spinning light display·
Want cheap wholesale electronic parts?
Transistor parts wholesale
It's like that with a lot of specialized tooling. If it costs $100,000 up front just to set up a manufacturing run (never mind material costs, packaging, etc.) but you're only going to sell 5000 units, then you've got $20 per unit that must be passed along to the end user. And those kind of costs to the end user have a tendency to multiply by a factor of 3 to 10 by the time they hit the shelves. So, without even counting materials, etc. you've got $60 or so in set up costs. When you sell lots and lots of things, then you can benefit from the "economies of scale." en.wikipedia.org/wiki/Economics_of_scale Otherwise you must fork it out. Best thing to do in a case like this is find a cheaper alternative that is sold to the masses.
"Now Mr. Jones, you claim that vibration in the plaintiff's factory led to the failure of that connector and, thence, to the tragic accident. But please explain to the court why, if this connection was so vital to the function and safety of your equipment, you didn't use the crimping tool recommended by the manufacturer."
Leons suggestion is good for small wire, I also use http://www.parts-express.com/pe/showdetl.cfm?Partnumber=360-642 and http://www.parts-express.com/pe/showdetl.cfm?Partnumber=360-646 for thicker wire.
One other issue is the correctness of the crimp.
When working in Avionics, I once had to go behind another technician who thought freehand crimping was a perfectly good practice. Now mind you these pins were not the standard fold two sides, but a 4 way crimp (4 dimples exactly 90 degrees apart). The pins were going into a $325.00 cannon plug. Needless to say the plug was special (as most are on aircraft), and the pins wouldn't release with the release tool. Not only did I have to totally redo the job with the correct tool, the previous technician had to replace the connector, which the pins were stuck inside. He was not happy, and found free-handing an expensive experience.
Those crimp tools were way over $500.00 each.....but the facility did provide them. Each different cannon plug required a different depth die. The technician before me was too lazy to go get the correct die, and found that the crimp was way more critical than he had ever expected.
There are many ways to crimp things wrong, even if you have the right tool. If you don't have the right tool, you may crimp it, and it may work, just don't bet your life on it.
James L
James L
Partner/Designer
Lil Brother SMT Assembly Services
Are you addicted to technology or Micro-controllers..... then checkout the forums at Savage Circuits. Learn to build your own Gizmos!
If I knew that I could find a crimper that would crimp both styles reliably I would not be afraid to lay out some cash. I just don't want to spend 400 on a crimper that will only crimp one connector.
For home-based work, I prefer Molex terminals because you can crimp almost any of theirs with the 63811-1000 Universal Crimp Tool. It was mentioned earlier by Todd as WM9999-ND from Digikey. The JST terminal does have "wings" that are very similar to many Molex terminals covered by this tool, so it may work. You have to crimp the wire and insulation separately, so it is not a quick tool and it does depend a lot on the operator for quality crimps.
The cost of crimp tools is a thorn in my side as I am in charge of all tooling for the cable assembly department at work. So far this year, I have probably spent about $2500 on crimp tools. Proper crimp tooling can make or break your quality. At work, we only use manufacturer specified crimp tools or applicators. This is the only surefire way to guarantee all of your crimps are within specification regardless of the operator performing the crimp.
The Crimp Quality Handbook posted by ElectricEye is very good to use as a reference and to learn about proper crimping. We use it during some training, but our governing specification is usually IPC/WHMA-A-620 "Requirements and Acceptance for Cable and Wire Harness Assemblies". IPC also has a quick reference book that can be downloaded as a low-res demo PDF, (DRM-WHA-A.PDF )
Andrew Williams
WBA Consulting
WBA-TH1M Sensirion SHT11 Module
Special Olympics Polar Bear Plunge, Mar 20, 2010
Andrew Williams
WBA Consulting
The two parts of a crimper (the die and anvil) are what perform the crimp to a specification. As long as these two "halves" of the alternative crimper are close enough to the specifications of the proper crimper, then the resultant crimp will be acceptable.
Andrew Williams
WBA Consulting
Andrew Williams
WBA Consulting
