PropBASIC (Preliminary Examples) — Parallax Forums
BeanBean Posts: 8,129
edited 2009-11-13 14:45 in Propeller 1
Okay, so I finally made a decision on my Propeller BASIC compiler.
I've decided to translate BASIC into Propeller Assembly....Just native assembly for the moment, but when the IDE support LMM, I will update it to that.
The main reason for this is that I can reuse a bunch of the code from the SX/B compiler. And users need help learning Propeller assembly as well as spin.
I have really just gotten started and here is some BASIC code and what gets generated:
DEVICE P8X32A, XTAL1, PLL16X
FREQ 80_000_000
Mask  CON %0000_0000_0000_0000_1000_0000_0000_0000
temp1  VAR LONG
PROGRAM Start
Start:
  DIRA = Mask
Again:
  OUTA = Mask
  PAUSE 10
  OUTA = 0
  PAUSE 10
  GOTO Again
END
''  *** COMPILED WITH PropBasic VERSION 0.00.01  08/27/2009 ***
CON                              'DEVICE P8X32A, XTAL1, PLL16X
  _ClkMode = XTAL1 + PLL16X
  _XInFreq =   5000000           'FREQ 80_000_000
' Mask  CON %0000_0000_0000_0000_1000_0000_0000_0000 'Mask  CON %0000_0000_0000_0000_1000_0000_0000_0000
' temp1  VAR LONG                'temp1  VAR LONG
PUB Main                         'PROGRAM Start
  CogNew(@__PROGSTART, 0)
DAT
__PROGSTART
  JMP #Start
Start                            'Start:
  MOV DIRA,Mask                  '  DIRA = Mask
Again                            'Again:
  MOV OUTA,Mask                  '  OUTA = Mask
  MOV __PARAM1,CNT               '  PAUSE 10
  ADD __PARAM1,_80000
  MOV __PARAM2,#10
L0001
  WAITCNT __PARAM1,_80000
  DJNZ __PARAM2,#L0001
  MOV OUTA,#0                    '  OUTA = 0
  ADD __PARAM1,_80000
  MOV __PARAM2,#10
L0002
  DJNZ __PARAM2,#L0002
  JMP #Again                     '  GOTO Again
  JMP #$                         'END
_32768
Mask             LONG 32768
_80000           LONG 80000
__PARAM1         RES 1
__PARAM2         RES 1
__PARAM3         RES 1
__PARAM4         RES 1
__PARAMCNT       RES 1
temp1            RES 1
CON
The BASIC code should look very familiar to SX/B users.
You can see how any constants > 511 are defined with a underscore prefix.
The final CON line in the propeller code is for any constants that are defined that are less than 512 (there aren't any in this program).
Any comments are welcomed.
Bean.
Does that byte of memory hold "A", 65, $41 or %01000001 ?
Yes it does...
Post Edited (Bean (Hitt Consulting)) : 10/15/2009 2:00:21 AM GMT
«13
    edited 2009-08-28 01:56
    Neat, might be a way for me to get started with PASM
    edited 2009-08-28 02:06
    Woot! This is so exciting. C users get C and now Basic users will get Basic. Thanks ++ Bean.
    Deep in the files of my computer are some code examples of a Basic compiler showing how it converts each instruction to Z80 assembly. None of it looked hugely complicated. Just a bit tedious coding each instruction.
    Some things should end up only a few asm instructions. While/Wend, For/Next and Do/Loop, If/Endif I've got all the string functions in Z80 assembly if this might be helpful, though they are not that hard to code. Left(), Mid(), Right(), Instr(), Hex(), Asc(), Chr() are core examples.
    Integer math should be fairly easy. Floating point math is harder but I have seen that done.
    Some structures need a little more thinking about, eg 'if a=5 then' vs 'a=5'. No == there to make it easier on the compiler. But it isn't hard to search for the 'if' and/or 'then' somewhere in the line.
    And there are a few instructions one misses in Basic (well at least some forms of basic) that should be one-liners to convert to assembly. Eg binary logic
    a=a and 01000111
    a=a nand 0111111
    a=a or 0111111
    a=a not 01010101
    a=a xor 11110000
    I could write pages. But I'd like to contribute something too in a more tangible way. This is so exciting!
    edited 2009-08-28 02:27
    Looks very SX/B'ish smile.gif
    It should be blazingly fast, and the code size limit may not matter for a lot of the small examples.
    One suggestion: write a PAUSE subroutine, then you can just go:
    mov _pausems,#10
    call #pause
    If it is used more than once in the program you win BIG on memory space.
    Personally, I think this will be an invaluable tool to teach guys who use PBASIC how to write PASM code - just like SX/B was a great way to learn SX programming.
    Bean (Hitt Consulting) said...
    FREQ 80_000_000
    temp1  VAR LONG
    PROGRAM Start
    Start:
      DIRA = Mask
    Again:
      OUTA = Mask
      PAUSE 10
      OUTA = 0
      PAUSE 10
      GOTO Again
    END
    DAT
    __PROGSTART
      JMP #Start
    Start                            'Start:
    Again                            'Again:
      ADD __PARAM1,_80000
      MOV __PARAM2,#10
    L0001
      ADD __PARAM1,_80000
      MOV __PARAM2,#10
    L0002
      JMP #$                         'END
    _32768
    Mask             LONG 32768
    _80000           LONG 80000
    __PARAM1         RES 1
    __PARAM2         RES 1
    __PARAM3         RES 1
    __PARAM4         RES 1
    __PARAMCNT       RES 1
    temp1            RES 1
    CON
    Bean.
    Please use mikronauts _at_ gmail _dot_ com to contact me off-forum, my PM is almost totally full
    Morpheus & Mem+dual Prop SBC w/ 512KB kit $119.95, 2MB memory IO board kit $89.95, both kits $189.95
    www.mikronauts.com - my site 6.250MHz custom Crystals for running Propellers at 100MHz
    Las - Large model assembler for the Propeller Largos - a feature full nano operating system for the Propeller
    edited 2009-08-28 05:11
    Bean! This is fantastic! When will it be ready for use?
    How will it differ from FemtoBASIC? (in a nutshell)
    Do you have a tiny beta PropBasic pre-release version
    that I can try out on the demo board?
    humanoido
  • BeanBean Posts: 8,129
    edited 2009-08-28 12:14
    Humanoido,
    · femtoBasic is written in spin, so it pretty slow. But still a cool program considering it runs totally on the Propeller.
    · PropBASIC is a PC program that converts (translates) BASIC code into PASM (Propeller Assembly).
    · What I have shown is all that it does at the moment.
    · Give me a couple weeks and I should have something a little more useful.
    · After I get far enough, I'll ask Ken if we can make a private PropBASIC forum with a couple Alpha testers to really get it going.
    Bean.
    Yes it does...
  • Agent420Agent420 Posts: 439
    edited 2009-08-28 12:19
    Again:
      OUTA = Mask
      PAUSE 10
      OUTA = 0
      PAUSE 10
      GOTO Again
    END
    Looks interesting...· Would there be Spin compatibility for including Exchange objects for example?
    edited 2009-08-28 12:26
    Agent420, Actually part of my decision was based on the fact that spin does NOT have a GOTO.
    I don't see how I would be able to interface to the spin objects, but I'll have to think about it. Or maybe someone else has an idea of how to do it.
    Bean.
    Yes it does...
  • Peter VerkaikPeter Verkaik Posts: 3,956
    edited 2009-08-28 13:27
    Hi Bean,
    Great start.
    If I may make a suggestion:
    Could you use
    Mask· DAT %0000_0000_0000_0000_1000_0000_0000_0000
    temp1· DAT LONG
    as these use program storage (initialized and not initialized) in DAT area
    and reserve CON for constant values that are not stored,
    like the constant 10 in
    · MOV __PARAM2,#10·············
    edit:
    or use COG since these variables are in cogmemory
    Mask· COG %0000_0000_0000_0000_1000_0000_0000_0000temp1· COG LONG
    regards peter
    Post Edited (Peter Verkaik) : 8/28/2009 1:36:24 PM GMT
  • T&E EngineerT&E Engineer Posts: 1,396
    edited 2009-08-28 13:44
    Bean,
    This is fantastic! I am ready to buy a Propeller system! I already know SX/B and it should be easy to get into it. Can you mix Assembler or SPIN in with the Propeller BASIC? What about doing video, PS2 keyboard, mouse, etc.
    This opens up some doors and I will not abandon the SX chip.··If I want video, PS2 capabilities and speed, then go with the more expensive Propeller but if not needed, then go with the less expensive SX28 or SX48.
    We will need some translation help from SPIN to Propeller BASIC most likely also.
    I will definately follow this post!
    edited 2009-08-28 13:58
    A little forum dedicated to this sounds great. I'm happy to be an alpha tester.
    The basic to z80 assembler I mentioned earlier is from oshonsoft. It has some great examples of how things get translated. Very little in the way of strings, but it does have floating point. I can post the instruction set and heater is our resident expert on both Z80 opcodes and pasm.
    For example, this is what it does with
    Dim a As Integer
    Dim b As Integer
    Dim c As Integer
    c = a + b
    End
    to
    ; Begin
        LD IX,0FF00H
        LD SP,0FEFAH
    ; 1: Dim a As Integer
    ;       The address of 'a' is IX-2 (FEFEH)
    ; 2: Dim b As Integer
    ;       The address of 'b' is IX-4 (FEFCH)
    ; 3: Dim c As Integer
    ;       The address of 'c' is IX-6 (FEFAH)
    ; 4: c = a + b
        LD L,(IX-02H)
        LD H,(IX-01H)
        LD E,(IX-04H)
        LD D,(IX-03H)
        ADD HL,DE
        LD (IX-06H),L
        LD (IX-05H),H
    ; 5: End
        HALT
    ; End of program
        HALT
    ; End of listing
        .END
    One thing that is nice about that is the comments it adds automatically and also the line numbers so you can see what each line of basic has been converted to. The principles would be the same for pasm. By breaking it down into manageable pieces the whole project is not so daunting. The instruction set is small and I'd want some more than this, but it is a start and every one of those instructions translates 1:1 to some assembly so examples of each ought to be useful. Translating z80 to pasm is something I might have to look at (or ask heater!). But I think it ends up with not many assembly instructions to learn. cc below from the beginning of the instruction manual. Some of these are going to be easy, but the floating point I think could be very useful.
    The list of all Basic compiler keywords:
    DIM, AS, BOOLEAN, SHORT, INTEGER, LONG, SINGLE, TRUE, FALSE, CONST, MOD, NOT, AND, OR, XOR, NAND, NOR, NXOR, SQR, SIN, COS, TAN, EXP, LN, LOG, GOTO, FOR, TO, STEP, NEXT, WHILE, WEND, IF, THEN, ELSE, ENDIF, POKE, PEEK, SETBIT, RESETBIT, TESTBIT, MAKEBIT, GET, PUT, PRINT, LF, CRLF, END, GOSUB, RETURN
    Default extension for basic source files is BAS. The compiler output is assembler source file (with ASM extension) that can be translated to binary code using integrated assembler. Smart editor marks all reserved keywords in different color, that simplifies debugging process.
    Five data types are supported:
    - Boolean (1-byte, True or False)
    - Short (1-byte integers in the range -128 to 127)
    - Integer (2-byte integers in the range -32,768 to 32,767)
    - Long (4-byte integers in the range -2,147,483,648 to 2,147,483,647)
    - Single (4-byte floating point, 7 digits precision, IEEE 754)
    Post Edited (Dr_Acula) : 8/28/2009 2:06:11 PM GMT
  • RsadeikaRsadeika Posts: 3,882
    edited 2009-08-28 14:33
    Bean, I may have missed it in one of the other threads, but, could you list the commands that you will be implementing. Also, how will
    you be implementing cognew/coginit? Will you be using the same 'Task' command in PropBASIC?
    Ray
  • Little-endianLittle-endian Posts: 91
    edited 2009-08-28 14:44
    Bean++
    edited 2009-08-28 14:52
    What I'd like to see are the highlevel constructs
    DO-LOOP, FOR-NEXT, IF-THEN-ELSE etc.
    plus integermath on variables. Since there is only 1·variable type in COGs
    (long) that should be doable. Further the elementary keywords
    INPUT, OUTPUT, LOW, HIGH to manipulate pins, using predefined
    pinnames PIN0 to PIN31 (so DIRA,·INA·and OUTA need not be used
    at the propbasic level).
    Regarding subroutines and functions, the simple GOSUB would suffice,
    given the·very limited cog address space.
    Edit:
    And the ability to use long arrays
    eg.
    tempArray COG LONG(7) 'create uninitialized long array
    tempArray(1) = 1234 + tempArray(3)
    regards peter
    Post Edited (Peter Verkaik) : 8/28/2009 3:05:23 PM GMT
    edited 2009-08-28 15:17
    @Dr_Acula
    He is a scientist (Physicist) in Serbia.
    It would be great if we could get him to write a basic for the prop!
    His stuff has the best little IDEs you ever saw.
    I have never really used basic, but this seems like a super project!
    - Some mornings I wake up cranky.....but usually I just let him sleep in -
    edited 2009-08-28 15:56
    Bean,
    Could you elaborate on your ideas?
    I can see something like this:
    mycon1 con 12 'constants
    mycon2 con 23
    myvar1 var long   'variables in hubram var section
    myvar2 var long(5)
    mydat1 dat long   'variables in hubram dat section
    mydat2 dat long
    mycog1 cog long 234  'variables in cogram
    mycog2 cog long(3)
    PROGRAM
     'here goes the basic program
    END
    compiles into a spin file
    CON
    mycon1 = 12
    mycon2 = 23
    VAR
    myvar1 long
    myvar2 long(5)
    DAT
    mydat1 long
    mydat2 long
    PUBLIC start
      cognew()
    PUBLIC stop
      cogstop()
    DAT
        org 0
    'compiled basic code
    mycog1 long 234
    mycog2 res 3
    end
    that we can import into a spin application file.
    regards peter
  • Mike HuseltonMike Huselton Posts: 746
    edited 2009-08-28 16:36
    Good for you!
    Perhaps you could at least look at Holly's suggestion. Holly, I would like to contact this person.
    JMH
    edited 2009-08-28 17:04
    Bean,
    I think PASM can not address VAR and DAT variables, only via the PAR parameter.
    So you could have something like this
    mycon2 con 23
    mycog2 cog long(3)
    MODULE
    END
    that compiles into
    CON
    mycon1 = 12
    mycon2 = 23
    PUBLIC start(addressOfPartable)
      cognew(...,addressOfPartable)
    PUBLIC stop
      cogstop(...)
    DAT
        org 0
    mycog1 long 234
    mycog2 res 3
    end
    Notice I changed PROGRAM to MODULE. Since your working from inside out (only native PASM now)
    the term PROGRAM would be used for when it is possible to write an entire program in basic.
    regards peter
  • CassLanCassLan Posts: 586
    edited 2009-08-28 20:44
    Little-endian said...
    Bean++
    Rick
    NYC Area Prop Club
    Prop Forum Search (Via Google)
    edited 2009-08-28 20:54
    @James Michael Huselton
    www.oshonsoft.com/contact.php
    www.oshonsoft.com/author.html
    He lives very close to Mikroelektronika, they make
    the best dev boards I ever saw! I wish they had some
    for the propeller.
    www.mikroe.com/en/tools/easyarm/
  • CounterRotatingPropsCounterRotatingProps Posts: 1,132
    edited 2009-08-28 21:34
    Bean,
    very commendable to go with your SX/B - style translator... I've mentioned many times before that SX/B helps me learn SASM.
    (But please, don't call it " Prop/B " or the propeller will start sounding like a California political animal. [noparse]:)[/noparse])
    thanks for your work!
    cheers
    - Howard
  • KMyersKMyers Posts: 433
    edited 2009-08-28 21:59
    Great job! I will definately look forward to a basic compilier for the Prop!
    Ken
  • DynamoBenDynamoBen Posts: 366
    edited 2009-08-29 05:00
    Thanks Bean, personally I like this idea because I can use it to improve my PASM abilities.
  • technoweaseltechnoweasel Posts: 10
    edited 2009-08-29 17:30
    I just started a project to make a BASIC compiler for the Propeller!!! I even called it "PropBasic!!!" Seriously, I spent last night writing a beginning·parser, tokenizer, and backend.·I can't believe this happened! I'm not sure if I should continue, since you have a head start and you seem to be a better programmer anyway.· freaked.gif I wish this forum had the smiley face that continuously runs into a brick wall!!!
    There are 10 types of people in the world, those who understand binary and those who don't.·· -a poster I saw
    edited 2009-08-29 17:40
    Maybe I should convert it to LISP! WOW!!!!! Here's my CodeBlocks C project file's properties to prove it.
    367 x 502 - 29K
    pb.jpg 29.3K
    edited 2009-08-29 18:55
    technoweasel
    I think one of the worst logic jokes, for a strap line, was "2b or not 2b = ff"
    Edit
    I took out binary and put in logic, before purists pointed out it's Hex.
    Style and grace : Nil point
    Post Edited (Toby Seckshund) : 8/29/2009 7:05:47 PM GMT
    edited 2009-08-29 21:54
    LOL - nothing like killing a good joke, eh? [noparse]:)[/noparse])
    @technoweasel - I'd not stop working on it because you will learn a lot by doing so. Consider also that there are several versions of compliers and debuggers being worked on at the same time. And what's great about here: these folks help each other, not competing.
    And you might come up with something no one else has thought of!
    cheers
    - Howard
    edited 2009-08-29 23:37
    Well sorry about your luck....I already registered the domain propbasic.com
    Bean
    Yes it does...
  • $WMc%$WMc% Posts: 1,884
    edited 2009-08-30 02:53
    Forum Moderator
    I would "Kill" to have a Propeller/Basic complier. Just the thought of having the power of the Propeller and me being able to
    write to it easily is to good. (This is why I like the $BasicStamps)
    I have all the Prop stuff, Prop.Pro.Dev.Board, Prop.Proto Board, Hydra Board, Expan.cards, Key board, mouse,
    Prop Clip, Prop Plug, Prop this and Prop that.
    My only problem with all of this is with Prop/ASM.
    It just takes way to much code for me to write/use.
    I quickly loose interest and return to my little favorites the BS2s
    I really like a registerd domain name "Prop/Basic".· oh-ya!
    I really hope Parallax rolls with this, Especially after the end of the SX-chips!!!!!!!
    ___________$WMc%____
    The Truth is out there············································ BoogerWoods, FL. USA
    Post Edited ($WMc%) : 8/30/2009 3:00:02 AM GMT
  • sestevesesteve Posts: 6
    edited 2009-08-30 03:53
    This looks VERY Cool! I will definitely .. DEFINITELY ... like to be a alpha/beta tester.
    - Steve
  • SRLMSRLM Posts: 5,045
    edited 2009-08-30 04:19
    I think it would probably be best to put variables in the hub. Otherwise, your programs will have to be even smaller than a BS2 program! It might also be nice to have a command like "LoadPage" that will copy (and run) a few hundred longs of code. Then, you could divide the code into blocks. You get the best of both PASM speed and spin size.
