USB Keyboard/Mouse?
Is it possible to interface a usb keyboard or mouse to the prop as if it were ps/2?· I have a diagram of the internal connections of one of those USB to PS/2 converters, and using usb keyboard/mouse would be a LOT cheaper and easier for one of my projects...
Thanks.
Quit buying all those fixed voltage regulators, and·get an Adjustable Power Supply·for your projects!· Includes an LED testing terminal!
Thanks.
That connector is simple an eletrical interface.
You can I believe find cheap converters from ps2 to usb... ans I believe there may be somthing that converters usb to ps2. Search newegg.com for some.
Nyamekye,
I have attached a hard earned schematic found on the last few pages of a google image search.·
Thanks.
As far as I remember there were some trys to get a usb-device working but the specs of usb have a very high level about timing
see this thread http://forums.parallax.com/showthread.php?p=764744
best regards
Stefan
It would be excellent to use usb instead of my ps/2 keyboard with a bunch of bent pins...
Thanks.
from your last post I'm not sure if you understood what I meant.
EVERY PURE USB-device will NOT WORK with the propeller DIRECTLY.
ONLY devices that can CHANGE their bitbanging on the wires to the OLD PS/2-protocol will work with the propeller.
For brandnew PURE USB-devices you have to use the FTDI-vinculum-chip as an interface that translates from USB-protocol
to RS232-serial or SPI
best regards
Stefan
I know that it would be stupid to try to interface a device such as a usb flash drive using the same connection, as the Vinculum thingy does that, and it isn't *too* expensive....
Thanks for your help and advice.
*Peter*
It's been in daily use 24/7 for me for over a year now [noparse]:)[/noparse]
Serial-ACM USB-serial emulator to a linux host (with UHCI patches to allow it to work low-speed).
Missed it by ->" "<- that much!
